Datasheet Wago 231-324/026-000 — Даташит
1-проводниковая розетка; 2,5 мм²; Шаг контактов 5,08 мм; 24-пол.
![]() 15 предложений от 6 поставщиков 1-CONDUCTOR FEMALE PLUG; 2.5 MM; | |||
231-324/026-000 | от 3 674 ₽ | ||
231-324/026-000 Wago | 7 258 ₽ | ||
231-324/026-000/RN01-0000 | по запросу | ||
231-324/026-000 Wago | по запросу |
Цвет | orange |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 26.45 mm / 1.041 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.608 MJ |
GTIN | 4044918350471 |
Height | 14.3 mm / 0.563 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Number of Poles | 24 |
Number of levels | 1 |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 24 |
Total number of potentials | 24 |
Вес | 43.411 г |
Ширина | 123.42 mm / 4.859 inch |
Серия: 231 (100 из 1349)
- 231-316/008-000 231-316/026-000 231-316/027-000 231-316/031-000 231-316/037-000 231-316/102-000 231-316/107-000 231-317/008-000 231-317/026-000 231-317/027-000 231-317/031-000 231-317/037-000 231-317/102-000 231-318/008-000 231-318/026-000 231-318/027-000 231-318/031-000 231-318/037-000 231-318/102-000 231-319/008-000 231-319/026-000 231-319/027-000 231-319/031-000 231-319/037-000 231-319/102-000 231-320/008-000 231-320/026-000 231-320/027-000 231-320/031-000 231-320/037-000 231-320/102-000 231-321/008-000 231-321/026-000 231-321/027-000 231-321/031-000 231-321/037-000 231-321/102-000 231-322/008-000 231-322/026-000 231-322/027-000 231-322/031-000 231-322/037-000 231-322/102-000 231-323/008-000 231-323/026-000 231-323/027-000 231-323/031-000 231-323/037-000 231-323/102-000 231-324/008-000 231-324/026-000 231-324/027-000 231-324/031-000 231-324/037-000 231-324/102-000 231-332/001-000 231-332/001-000/105-604 231-332/108-000 231-333/001-000 231-333/001-000/105-604 231-333/108-000 231-334/001-000 231-334/108-000 231-335/001-000 231-335/108-000 231-336/001-000 231-336/108-000 231-337/001-000 231-337/108-000 231-338/001-000 231-338/108-000 231-339/001-000 231-339/108-000 231-340/001-000 231-340/108-000 231-341/001-000 231-342/001-000 231-342/108-000 231-343/001-000 231-344/001-000 231-344/108-000 231-345/001-000 231-345/108-000 231-346/001-000 231-346/108-000 231-347/001-000 231-348/001-000 231-349/001-000 231-350/001-000 231-351/001-000 231-352/001-000 231-353/001-000 231-354/001-000 231-362/001-000 231-362/108-000 231-363/001-000 231-363/108-000 231-364/001-000 231-364/108-000 231-365/001-000
231324/026000, 231 324/026 000
