Datasheet Wago 231-332/001-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; Шаг контактов 5,08 мм; 2-пол.
![]() 30 предложений от 15 поставщиков 231-332/001-000, 2-контакт. вилка, шаг 5,08 мм, на печ. плату, оранжевая | |||
231-332/001-000 Wago | 35 ₽ | ||
231-332/001-000 Wago | от 112 ₽ | ||
231-332/001-000 Wago | от 123 ₽ | ||
231-332/001-000 Littelfuse | по запросу |
Цвет | orange |
Connector connection type | for PCBs |
Country of origin | PL |
Габариты: глубина | 8.4 mm / 0.331 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.017 MJ |
GTIN | 4044918865173 |
Height | 17 mm / 0.669 inch |
Height from the surface | 12 mm / 0.472 inch |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 2 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 2 |
Вес | 0.816 г |
Ширина | 13.28 mm / 0.523 inch |
Серия: 231 (100 из 1349)
- 231-316/102-000 231-316/107-000 231-317/008-000 231-317/026-000 231-317/027-000 231-317/031-000 231-317/037-000 231-317/102-000 231-318/008-000 231-318/026-000 231-318/027-000 231-318/031-000 231-318/037-000 231-318/102-000 231-319/008-000 231-319/026-000 231-319/027-000 231-319/031-000 231-319/037-000 231-319/102-000 231-320/008-000 231-320/026-000 231-320/027-000 231-320/031-000 231-320/037-000 231-320/102-000 231-321/008-000 231-321/026-000 231-321/027-000 231-321/031-000 231-321/037-000 231-321/102-000 231-322/008-000 231-322/026-000 231-322/027-000 231-322/031-000 231-322/037-000 231-322/102-000 231-323/008-000 231-323/026-000 231-323/027-000 231-323/031-000 231-323/037-000 231-323/102-000 231-324/008-000 231-324/026-000 231-324/027-000 231-324/031-000 231-324/037-000 231-324/102-000 231-332/001-000 231-332/001-000/105-604 231-332/108-000 231-333/001-000 231-333/001-000/105-604 231-333/108-000 231-334/001-000 231-334/108-000 231-335/001-000 231-335/108-000 231-336/001-000 231-336/108-000 231-337/001-000 231-337/108-000 231-338/001-000 231-338/108-000 231-339/001-000 231-339/108-000 231-340/001-000 231-340/108-000 231-341/001-000 231-342/001-000 231-342/108-000 231-343/001-000 231-344/001-000 231-344/108-000 231-345/001-000 231-345/108-000 231-346/001-000 231-346/108-000 231-347/001-000 231-348/001-000 231-349/001-000 231-350/001-000 231-351/001-000 231-352/001-000 231-353/001-000 231-354/001-000 231-362/001-000 231-362/108-000 231-363/001-000 231-363/108-000 231-364/001-000 231-364/108-000 231-365/001-000 231-365/108-000 231-366/001-000 231-366/108-000 231-367/001-000 231-367/108-000
231332/001000, 231 332/001 000
