Datasheet Wago 231-344/001-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; Шаг контактов 5,08 мм; 14-пол.
THT MALE HEADER; 1.0 X 1.0 MM SO | |||
| 231-344/001-000 Wago | по запросу | ||
| 231-344/001-000 Littelfuse | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 8.4 mm / 0.331 inch |
| Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
| Fire load | 0.081 MJ |
| GTIN | 4044918865692 |
| Height | 17 mm / 0.669 inch |
| Height from the surface | 12 mm / 0.472 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 14 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 14 |
| Вес | 4.59 г |
| Ширина | 74.24 mm / 2.923 inch |
Серия: 231 (100 из 1349)
- 231-320/037-000 231-320/102-000 231-321/008-000 231-321/026-000 231-321/027-000 231-321/031-000 231-321/037-000 231-321/102-000 231-322/008-000 231-322/026-000 231-322/027-000 231-322/031-000 231-322/037-000 231-322/102-000 231-323/008-000 231-323/026-000 231-323/027-000 231-323/031-000 231-323/037-000 231-323/102-000 231-324/008-000 231-324/026-000 231-324/027-000 231-324/031-000 231-324/037-000 231-324/102-000 231-332/001-000 231-332/001-000/105-604 231-332/108-000 231-333/001-000 231-333/001-000/105-604 231-333/108-000 231-334/001-000 231-334/108-000 231-335/001-000 231-335/108-000 231-336/001-000 231-336/108-000 231-337/001-000 231-337/108-000 231-338/001-000 231-338/108-000 231-339/001-000 231-339/108-000 231-340/001-000 231-340/108-000 231-341/001-000 231-342/001-000 231-342/108-000 231-343/001-000 231-344/001-000 231-344/108-000 231-345/001-000 231-345/108-000 231-346/001-000 231-346/108-000 231-347/001-000 231-348/001-000 231-349/001-000 231-350/001-000 231-351/001-000 231-352/001-000 231-353/001-000 231-354/001-000 231-362/001-000 231-362/108-000 231-363/001-000 231-363/108-000 231-364/001-000 231-364/108-000 231-365/001-000 231-365/108-000 231-366/001-000 231-366/108-000 231-367/001-000 231-367/108-000 231-368/001-000 231-368/108-000 231-369/001-000 231-369/108-000 231-370/001-000 231-370/108-000 231-371/001-000 231-372/001-000 231-372/108-000 231-373/001-000 231-374/001-000 231-374/108-000 231-375/001-000 231-375/108-000 231-376/001-000 231-376/108-000 231-377/001-000 231-378/001-000 231-379/001-000 231-380/001-000 231-381/001-000 231-382/001-000 231-383/001-000 231-384/001-000
231344/001000, 231 344/001 000
