Datasheet Wago 231-384/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; прямые; Шаг контактов 5,08 мм; 24-пол.
Купить 231-384/001-000 на РадиоЛоцман.Цены — от 801 до 3 694 ₽ THT MALE HEADER; 1.2 X 1.2 MM SO | |||
231-384/001-000 Wago | 801 ₽ | ||
231-384/001-000 Wago | 3 694 ₽ | ||
231-384/001-000 Littelfuse | по запросу | ||
231-384/001-000 Wago | по запросу |
Цвет | orange |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 8.4 mm / 0.331 inch |
Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
Fire load | 0.133 MJ |
GTIN | 4044918930291 |
Height | 17 mm / 0.669 inch |
Height from the surface | 12 mm / 0.472 inch |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 24 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1.2 x 1.2 mm |
Solder pin length | 5 мм |
Total number of potentials | 24 |
Вес | 8.99 г |
Ширина | 125.04 mm / 4.923 inch |
Серия: 231 (100 из 1349)
- 231-343/001-000 231-344/001-000 231-344/108-000 231-345/001-000 231-345/108-000 231-346/001-000 231-346/108-000 231-347/001-000 231-348/001-000 231-349/001-000 231-350/001-000 231-351/001-000 231-352/001-000 231-353/001-000 231-354/001-000 231-362/001-000 231-362/108-000 231-363/001-000 231-363/108-000 231-364/001-000 231-364/108-000 231-365/001-000 231-365/108-000 231-366/001-000 231-366/108-000 231-367/001-000 231-367/108-000 231-368/001-000 231-368/108-000 231-369/001-000 231-369/108-000 231-370/001-000 231-370/108-000 231-371/001-000 231-372/001-000 231-372/108-000 231-373/001-000 231-374/001-000 231-374/108-000 231-375/001-000 231-375/108-000 231-376/001-000 231-376/108-000 231-377/001-000 231-378/001-000 231-379/001-000 231-380/001-000 231-381/001-000 231-382/001-000 231-383/001-000 231-384/001-000 231-393 231-426 231-432/001-000 231-432/001-000/105-604 231-432/001-000/105-604/997-405 231-432/040-000 231-433/001-000 231-433/001-000/105-604 231-433/001-000/105-604/997-405 231-433/040-000 231-434/001-000 231-434/001-000/105-604 231-434/001-000/105-604/997-407 231-435/001-000 231-435/001-000/105-604 231-435/040-000 231-436/001-000 231-436/001-000/105-604 231-436/001-000/105-604/997-407 231-436/040-000 231-437/001-000 231-437/001-000/105-604 231-437/001-000/105-604/997-407 231-438/001-000 231-438/001-000/105-604 231-438/001-000/105-604/997-407 231-439/001-000 231-439/001-000/105-604 231-439/001-000/105-604/997-409 231-440/001-000 231-440/001-000/105-604 231-440/001-000/105-604/997-409 231-441/001-000 231-441/001-000/105-604 231-441/001-000/105-604/997-409 231-442/001-000 231-442/001-000/105-604 231-442/001-000/105-604/997-409 231-443/001-000 231-444/001-000 231-444/040-000 231-445/001-000 231-446/001-000 231-447/001-000 231-448/001-000 231-449/001-000 231-450/001-000 231-451/001-000 231-452/001-000
231384/001000, 231 384/001 000
