Datasheet Wago 231-441/001-000/105-604 — Даташит
Вилка под пайку THR; 1.0 x 1.0 mm solder pin; угловые; Шаг контактов 5 мм; 11-пол.
Цвет | black |
Connector connection type | for PCBs |
Country of origin | PL |
Габариты: глубина | 12 mm / 0.472 inch |
GTIN | 4055143695350 |
Height | 10.8 mm / 0.425 inch |
Height from the surface | 8.4 mm / 0.331 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mismating protection | No |
Number of Poles | 11 |
Number of levels | 1 |
PCB contact | THR |
Packaging type | BOX |
Pin spacing | 5 mm (0.197 inch) |
Plated through-hole diameter (THR) | 1.4 (+ 0.1) мм |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1 mm |
Solder pin length | 2.4 мм |
Total number of potentials | 11 |
Вес | 3.53 г |
Ширина | 58.2 mm / 2.291 inch |
Серия: 231 (100 из 1349)
- 231-372/001-000 231-372/108-000 231-373/001-000 231-374/001-000 231-374/108-000 231-375/001-000 231-375/108-000 231-376/001-000 231-376/108-000 231-377/001-000 231-378/001-000 231-379/001-000 231-380/001-000 231-381/001-000 231-382/001-000 231-383/001-000 231-384/001-000 231-393 231-426 231-432/001-000 231-432/001-000/105-604 231-432/001-000/105-604/997-405 231-432/040-000 231-433/001-000 231-433/001-000/105-604 231-433/001-000/105-604/997-405 231-433/040-000 231-434/001-000 231-434/001-000/105-604 231-434/001-000/105-604/997-407 231-435/001-000 231-435/001-000/105-604 231-435/040-000 231-436/001-000 231-436/001-000/105-604 231-436/001-000/105-604/997-407 231-436/040-000 231-437/001-000 231-437/001-000/105-604 231-437/001-000/105-604/997-407 231-438/001-000 231-438/001-000/105-604 231-438/001-000/105-604/997-407 231-439/001-000 231-439/001-000/105-604 231-439/001-000/105-604/997-409 231-440/001-000 231-440/001-000/105-604 231-440/001-000/105-604/997-409 231-441/001-000 231-441/001-000/105-604 231-441/001-000/105-604/997-409 231-442/001-000 231-442/001-000/105-604 231-442/001-000/105-604/997-409 231-443/001-000 231-444/001-000 231-444/040-000 231-445/001-000 231-446/001-000 231-447/001-000 231-448/001-000 231-449/001-000 231-450/001-000 231-451/001-000 231-452/001-000 231-453/001-000 231-454/001-000 231-455 231-462/001-000 231-462/001-000/105-604 231-462/001-000/105-604/997-405 231-462/040-000 231-463/001-000 231-463/001-000/105-604 231-463/001-000/105-604/997-405 231-463/040-000 231-464/001-000 231-464/001-000/105-604 231-464/001-000/105-604/997-407 231-465/001-000 231-465/001-000/105-604 231-465/001-000/105-604/997-407 231-465/040-000 231-466/001-000 231-466/001-000/105-604 231-466/001-000/105-604/997-407 231-466/040-000 231-467/001-000 231-467/001-000/105-604 231-467/001-000/105-604/997-407 231-468/001-000 231-468/001-000/105-604 231-468/001-000/105-604/997-407 231-469/001-000 231-469/001-000/105-604 231-469/001-000/105-604/997-409 231-470/001-000 231-470/001-000/105-604 231-470/001-000/105-604/997-409
231441/001000/105604, 231 441/001 000/105 604
