Datasheet Wago 231-474/040-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; угловые; зажимное кольцо; Шаг контактов 5 мм; 14-пол.
THT MALE HEADER; 1.2 X 1.2 MM SO | |||
| 231-474/040-000 Wago | по запросу | ||
| Цвет | gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 12 mm / 0.472 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fire load | 0.121 MJ |
| GTIN | 4044918930710 |
| Height | 12.2 mm / 0.48 inch |
| Height from the surface | 8.4 mm / 0.331 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 14 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1.2 x 1.2 mm |
| Solder pin length | 3.8 мм |
| Total number of potentials | 14 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 6.69 г |
| Ширина | 82.8 mm / 3.26 inch |
Серия: 231 (100 из 1349)
- 231-445/001-000 231-446/001-000 231-447/001-000 231-448/001-000 231-449/001-000 231-450/001-000 231-451/001-000 231-452/001-000 231-453/001-000 231-454/001-000 231-455 231-462/001-000 231-462/001-000/105-604 231-462/001-000/105-604/997-405 231-462/040-000 231-463/001-000 231-463/001-000/105-604 231-463/001-000/105-604/997-405 231-463/040-000 231-464/001-000 231-464/001-000/105-604 231-464/001-000/105-604/997-407 231-465/001-000 231-465/001-000/105-604 231-465/001-000/105-604/997-407 231-465/040-000 231-466/001-000 231-466/001-000/105-604 231-466/001-000/105-604/997-407 231-466/040-000 231-467/001-000 231-467/001-000/105-604 231-467/001-000/105-604/997-407 231-468/001-000 231-468/001-000/105-604 231-468/001-000/105-604/997-407 231-469/001-000 231-469/001-000/105-604 231-469/001-000/105-604/997-409 231-470/001-000 231-470/001-000/105-604 231-470/001-000/105-604/997-409 231-471/001-000 231-471/001-000/105-604 231-471/001-000/105-604/997-409 231-472/001-000 231-472/001-000/105-604 231-472/001-000/105-604/997-409 231-473/001-000 231-474/001-000 231-474/040-000 231-475/001-000 231-476/001-000 231-477/001-000 231-478/001-000 231-479/001-000 231-480/001-000 231-481/001-000 231-482/001-000 231-483/001-000 231-484/001-000 231-500 231-532/001-000 231-532/001-000/105-604 231-532/001-000/105-604/997-405 231-532/108-000 231-533/001-000 231-533/001-000/105-604 231-533/001-000/105-604/997-405 231-533/108-000 231-534/001-000 231-534/108-000 231-535/001-000 231-535/108-000 231-536/001-000 231-536/108-000 231-537/001-000 231-537/108-000 231-538/001-000 231-538/108-000 231-539/001-000 231-539/108-000 231-540/001-000 231-540/108-000 231-541/001-000 231-542/001-000 231-542/108-000 231-543/001-000 231-544/001-000 231-544/108-000 231-545/001-000 231-545/108-000 231-546/001-000 231-546/108-000 231-547/001-000 231-548/001-000 231-549/001-000 231-550/001-000 231-551/001-000 231-552/001-000
231474/040000, 231 474/040 000
