Datasheet Wago 231-584/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; угловые; Шаг контактов 5,08 мм; 24-пол.
| THT MALE HEADER; 1.2 X 1.2 MM SO | |||
| 231-584/001-000 Wago | 774 ₽ | ||
| 231-584/001-000 Littelfuse | по запросу | ||
| 231-584/001-000 Wago | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 12 mm / 0.472 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fire load | 0.133 MJ |
| GTIN | 4044918931700 |
| Height | 12.2 mm / 0.48 inch |
| Height from the surface | 8.4 mm / 0.331 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 24 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1.2 x 1.2 mm |
| Solder pin length | 3.8 мм |
| Total number of potentials | 24 |
| Вес | 8.99 г |
| Ширина | 125.04 mm / 4.923 inch |
Серия: 231 (100 из 1349)
- 231-543/001-000 231-544/001-000 231-544/108-000 231-545/001-000 231-545/108-000 231-546/001-000 231-546/108-000 231-547/001-000 231-548/001-000 231-549/001-000 231-550/001-000 231-551/001-000 231-552/001-000 231-553/001-000 231-554/001-000 231-562/001-000 231-562/108-000 231-563/001-000 231-563/108-000 231-564/001-000 231-564/108-000 231-565/001-000 231-565/108-000 231-566/001-000 231-566/108-000 231-567/001-000 231-567/108-000 231-568/001-000 231-568/108-000 231-569/001-000 231-569/108-000 231-570/001-000 231-570/108-000 231-571/001-000 231-572/001-000 231-572/108-000 231-573/001-000 231-574/001-000 231-574/108-000 231-575/001-000 231-575/108-000 231-576/001-000 231-576/108-000 231-577/001-000 231-578/001-000 231-579/001-000 231-580/001-000 231-581/001-000 231-582/001-000 231-583/001-000 231-584/001-000 231-602 231-602/017-000 231-602/018-000 231-602/019-000 231-602/023-000 231-602/114-000 231-603 231-603/017-000 231-603/018-000 231-603/019-000 231-603/023-000 231-603/032-000 231-603/114-000 231-604 231-604/017-000 231-604/018-000 231-604/019-000 231-604/023-000 231-604/114-000 231-605 231-605/017-000 231-605/018-000 231-605/019-000 231-605/023-000 231-605/114-000 231-606 231-606/017-000 231-606/018-000 231-606/019-000 231-606/023-000 231-606/114-000 231-607 231-607/017-000 231-607/018-000 231-607/019-000 231-607/019-000/034-000 231-607/023-000 231-607/114-000 231-608 231-608/017-000 231-608/018-000 231-608/019-000 231-608/023-000 231-608/114-000 231-609 231-609/017-000 231-609/018-000 231-609/019-000 231-609/023-000
231584/001000, 231 584/001 000
