Datasheet Wago 231-602/019-000 — Даташит
1-проводная вилка; зажимное кольцо; 2,5 мм²; Шаг контактов 5 мм; 2-пол.
Купить 231-602/019-000 на РадиоЛоцман.Цены — от 216 до 662 ₽17 предложений от 7 поставщиков 231-602/019-000, 2-контакт. вилка, шаг 5 мм, с креп. фланцами | |||
| 231-602/019-000 | от 532 ₽ | ||
| 231-602/019-000 Wago | от 662 ₽ | ||
| 231-602/019000 Littelfuse | по запросу | ||
| 231-602/019-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 27.5 mm / 1.083 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.091 MJ |
| GTIN | 4044918256476 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 4.471 г |
| Ширина | 24.8 mm / 0.976 inch |
Серия: 231 (100 из 1349)
- 231-545/108-000 231-546/001-000 231-546/108-000 231-547/001-000 231-548/001-000 231-549/001-000 231-550/001-000 231-551/001-000 231-552/001-000 231-553/001-000 231-554/001-000 231-562/001-000 231-562/108-000 231-563/001-000 231-563/108-000 231-564/001-000 231-564/108-000 231-565/001-000 231-565/108-000 231-566/001-000 231-566/108-000 231-567/001-000 231-567/108-000 231-568/001-000 231-568/108-000 231-569/001-000 231-569/108-000 231-570/001-000 231-570/108-000 231-571/001-000 231-572/001-000 231-572/108-000 231-573/001-000 231-574/001-000 231-574/108-000 231-575/001-000 231-575/108-000 231-576/001-000 231-576/108-000 231-577/001-000 231-578/001-000 231-579/001-000 231-580/001-000 231-581/001-000 231-582/001-000 231-583/001-000 231-584/001-000 231-602 231-602/017-000 231-602/018-000 231-602/019-000 231-602/023-000 231-602/114-000 231-603 231-603/017-000 231-603/018-000 231-603/019-000 231-603/023-000 231-603/032-000 231-603/114-000 231-604 231-604/017-000 231-604/018-000 231-604/019-000 231-604/023-000 231-604/114-000 231-605 231-605/017-000 231-605/018-000 231-605/019-000 231-605/023-000 231-605/114-000 231-606 231-606/017-000 231-606/018-000 231-606/019-000 231-606/023-000 231-606/114-000 231-607 231-607/017-000 231-607/018-000 231-607/019-000 231-607/019-000/034-000 231-607/023-000 231-607/114-000 231-608 231-608/017-000 231-608/018-000 231-608/019-000 231-608/023-000 231-608/114-000 231-609 231-609/017-000 231-609/018-000 231-609/019-000 231-609/023-000 231-609/114-000 231-610 231-610/017-000 231-610/018-000
231602/019000, 231 602/019 000
