Datasheet Wago 231-613/019-000 — Даташит
1-проводная вилка; зажимное кольцо; 2,5 мм²; Шаг контактов 5 мм; 13-пол.
1-CONDUCTOR MALE CONNECTOR; CLAM | |||
| 231-613/019-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 27.5 mm / 1.083 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.369 MJ |
| GTIN | 4044918258548 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 13 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 13 |
| Total number of potentials | 13 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 20.7 г |
| Ширина | 79.8 mm / 3.142 inch |
Серия: 231 (100 из 1349)
- 231-605/019-000 231-605/023-000 231-605/114-000 231-606 231-606/017-000 231-606/018-000 231-606/019-000 231-606/023-000 231-606/114-000 231-607 231-607/017-000 231-607/018-000 231-607/019-000 231-607/019-000/034-000 231-607/023-000 231-607/114-000 231-608 231-608/017-000 231-608/018-000 231-608/019-000 231-608/023-000 231-608/114-000 231-609 231-609/017-000 231-609/018-000 231-609/019-000 231-609/023-000 231-609/114-000 231-610 231-610/017-000 231-610/018-000 231-610/019-000 231-610/019-000/035-000 231-610/023-000 231-610/114-000 231-611 231-611/017-000 231-611/018-000 231-611/019-000 231-611/023-000 231-611/114-000 231-612 231-612/017-000 231-612/018-000 231-612/019-000 231-612/019-000/035-000 231-612/023-000 231-612/114-000 231-613 231-613/018-000 231-613/019-000 231-613/114-000 231-614 231-614/018-000 231-614/019-000 231-614/114-000 231-615 231-615/018-000 231-615/019-000 231-615/114-000 231-616 231-616/018-000 231-616/019-000 231-616/114-000 231-617 231-617/018-000 231-617/019-000 231-617/114-000 231-618 231-618/018-000 231-618/018-000/035-000 231-618/019-000 231-618/114-000 231-619 231-619/018-000 231-619/019-000 231-619/114-000 231-620 231-620/018-000 231-620/019-000 231-620/019-000/035-000 231-620/114-000 231-621 231-621/018-000 231-621/019-000 231-621/114-000 231-622 231-622/018-000 231-622/019-000 231-622/114-000 231-623 231-623/018-000 231-623/019-000 231-623/114-000 231-624 231-624/018-000 231-624/019-000 231-624/114-000 231-632 231-632/017-000
231613/019000, 231 613/019 000
