Datasheet Wago 231-618/019-000 — Даташит
1-проводная вилка; зажимное кольцо; 2,5 мм²; Шаг контактов 5 мм; 18-пол.
![]() 15 предложений от 6 поставщиков 1-CONDUCTOR MALE CONNECTOR; CLAM | |||
231-618/019-000 Wago | 1 073 ₽ | ||
231-618/019-000 | от 2 575 ₽ | ||
231-618/019-000 Wago | 5 760 ₽ | ||
231-618/019-000 Wago | по запросу |
Цвет | gray |
Country of origin | DE |
Габариты: глубина | 27.5 mm / 1.083 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.495 MJ |
GTIN | 4044918259040 |
Height | 14.3 mm / 0.563 inch |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 18 |
Number of levels | 1 |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 18 |
Total number of potentials | 18 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 28.44 г |
Ширина | 104.8 mm / 4.126 inch |
Серия: 231 (100 из 1349)
- 231-608/114-000 231-609 231-609/017-000 231-609/018-000 231-609/019-000 231-609/023-000 231-609/114-000 231-610 231-610/017-000 231-610/018-000 231-610/019-000 231-610/019-000/035-000 231-610/023-000 231-610/114-000 231-611 231-611/017-000 231-611/018-000 231-611/019-000 231-611/023-000 231-611/114-000 231-612 231-612/017-000 231-612/018-000 231-612/019-000 231-612/019-000/035-000 231-612/023-000 231-612/114-000 231-613 231-613/018-000 231-613/019-000 231-613/114-000 231-614 231-614/018-000 231-614/019-000 231-614/114-000 231-615 231-615/018-000 231-615/019-000 231-615/114-000 231-616 231-616/018-000 231-616/019-000 231-616/114-000 231-617 231-617/018-000 231-617/019-000 231-617/114-000 231-618 231-618/018-000 231-618/018-000/035-000 231-618/019-000 231-618/114-000 231-619 231-619/018-000 231-619/019-000 231-619/114-000 231-620 231-620/018-000 231-620/019-000 231-620/019-000/035-000 231-620/114-000 231-621 231-621/018-000 231-621/019-000 231-621/114-000 231-622 231-622/018-000 231-622/019-000 231-622/114-000 231-623 231-623/018-000 231-623/019-000 231-623/114-000 231-624 231-624/018-000 231-624/019-000 231-624/114-000 231-632 231-632/017-000 231-632/018-000 231-632/019-000 231-632/023-000 231-632/109-000 231-632/114-000 231-632/129-000 231-633 231-633/017-000 231-633/018-000 231-633/019-000 231-633/023-000 231-633/109-000 231-633/114-000 231-633/129-000 231-634 231-634/017-000 231-634/018-000 231-634/019-000 231-634/023-000 231-634/109-000 231-634/114-000
231618/019000, 231 618/019 000
