Datasheet Wago 231-635/017-000 — Даташит
Клеммная колодка для сквозного монтажа на печатную плату; угловой штырь под пайку 1x1,2 мм; 5-полюсный; с фиксирующими фланцами; шаг контактов 5,08 мм / 0,2 дюйма; оранжевый
| Купить 231-635/017-000 на РадиоЛоцман.Цены — от 228 до 417 ₽ PCB TERMINAL BLOCK; 2.5 MM; PIN | |||
| 231-635/017-000 Wago | 228 ₽ | ||
| 231-635/017-000 Wago | 417 ₽ | ||
| 231-635/017-000 Wago | по запросу | ||
| 231-635/017-000 Littelfuse | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | DE |
| Габариты: глубина | 19.1 mm / 0.752 inch |
| Drilled hole diameter (tolerance) | 1.8(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.127 MJ |
| GTIN | 4044918283083 |
| Height | 19 mm / 0.748 inch |
| Height from the surface | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Mounting type | Mounting flange |
| Number of Poles | 5 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.8 x 1.3 mm |
| Solder pin length | 4.7 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 14 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 5 |
| Total number of potentials | 5 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 7.78 г |
| Ширина | 40.6 mm / 1.598 inch |
Серия: 231 (100 из 1349)
- 231-619 231-619/018-000 231-619/019-000 231-619/114-000 231-620 231-620/018-000 231-620/019-000 231-620/019-000/035-000 231-620/114-000 231-621 231-621/018-000 231-621/019-000 231-621/114-000 231-622 231-622/018-000 231-622/019-000 231-622/114-000 231-623 231-623/018-000 231-623/019-000 231-623/114-000 231-624 231-624/018-000 231-624/019-000 231-624/114-000 231-632 231-632/017-000 231-632/018-000 231-632/019-000 231-632/023-000 231-632/109-000 231-632/114-000 231-632/129-000 231-633 231-633/017-000 231-633/018-000 231-633/019-000 231-633/023-000 231-633/109-000 231-633/114-000 231-633/129-000 231-634 231-634/017-000 231-634/018-000 231-634/019-000 231-634/023-000 231-634/109-000 231-634/114-000 231-634/129-000 231-635 231-635/017-000 231-635/018-000 231-635/019-000 231-635/023-000 231-635/109-000 231-635/114-000 231-635/129-000 231-636 231-636/017-000 231-636/018-000 231-636/019-000 231-636/023-000 231-636/109-000 231-636/114-000 231-636/129-000 231-637 231-637/017-000 231-637/018-000 231-637/019-000 231-637/019-000/034-000 231-637/023-000 231-637/109-000 231-637/114-000 231-637/129-000 231-638 231-638/017-000 231-638/018-000 231-638/019-000 231-638/023-000 231-638/109-000 231-638/114-000 231-638/129-000 231-639 231-639/017-000 231-639/018-000 231-639/019-000 231-639/023-000 231-639/109-000 231-639/114-000 231-639/129-000 231-640 231-640/017-000 231-640/018-000 231-640/019-000 231-640/023-000 231-640/109-000 231-640/114-000 231-640/129-000 231-641 231-641/017-000
- PCB Interconnect
231635/017000, 231 635/017 000
