Datasheet Wago 231-650 — Даташит
1-проводная вилка; 2,5 мм²; Шаг контактов 5,08 мм; 20-пол.
Купить 231-650 на РадиоЛоцман.Цены — от 2 730 до 14 493 ₽13 предложений от 10 поставщиков 231-650/019-000, 20-контакт. вилка, шаг 5,08 мм, с креп. фланцами, оранжевая | |||
| 2316-50 | 2 730 ₽ | ||
| 2316-50 | 7 015 ₽ | ||
| 231-650/019-000 Wago | по запросу | ||
| 2316-50 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 27.5 mm / 1.083 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.501 MJ |
| GTIN | 4044918261180 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 20 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 20 |
| Total number of potentials | 20 |
| Вес | 30.81 г |
| Ширина | 104.8 mm / 4.126 inch |
Серия: 231 (100 из 1349)
- 231-640/114-000 231-640/129-000 231-641 231-641/017-000 231-641/018-000 231-641/019-000 231-641/023-000 231-641/114-000 231-642 231-642/017-000 231-642/018-000 231-642/019-000 231-642/023-000 231-642/109-000 231-642/114-000 231-642/129-000 231-643 231-643/018-000 231-643/019-000 231-643/114-000 231-644 231-644/018-000 231-644/019-000 231-644/109-000 231-644/114-000 231-644/129-000 231-645 231-645/018-000 231-645/019-000 231-645/109-000 231-645/114-000 231-645/129-000 231-646 231-646/018-000 231-646/019-000 231-646/109-000 231-646/114-000 231-646/129-000 231-647 231-647/018-000 231-647/019-000 231-647/114-000 231-648 231-648/018-000 231-648/019-000 231-648/114-000 231-649 231-649/018-000 231-649/019-000 231-649/114-000 231-650 231-650/018-000 231-650/019-000 231-650/114-000 231-651 231-651/018-000 231-651/019-000 231-651/114-000 231-652 231-652/018-000 231-652/019-000 231-652/114-000 231-653 231-653/018-000 231-653/019-000 231-653/114-000 231-654 231-654/018-000 231-654/018-000/035-000 231-654/019-000 231-654/114-000 231-661 231-662 231-668 231-669 231-670 231-671 231-672 231-702/008-000 231-702/026-000 231-702/031-000 231-702/037-000 231-703/008-000 231-703/026-000 231-703/031-000 231-703/037-000 231-704/008-000 231-704/026-000 231-704/031-000 231-704/037-000 231-705/008-000 231-705/026-000 231-705/031-000 231-705/037-000 231-706/008-000 231-706/026-000 231-706/027-000 231-706/031-000 231-706/037-000 231-707/008-000
