Datasheet Wago 231-770/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; прямые; Шаг контактов 7,62 мм; 10-пол.
THT MALE HEADER; 1.2 X 1.2 MM SO | |||
| 231-770/001-000 Wago | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 8.4 mm / 0.331 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fire load | 0.083 MJ |
| GTIN | 4044918931960 |
| Height | 17 mm / 0.669 inch |
| Height from the surface | 12 mm / 0.472 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 10 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 7.62 mm (0.3 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1.2 x 1.2 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 10 |
| Вес | 4.7 г |
| Ширина | 76.78 mm / 3.023 inch |
Серия: 231 (100 из 1349)
- 231-706/037-000 231-707/008-000 231-707/026-000 231-707/027-000 231-707/031-000 231-707/037-000 231-708/008-000 231-708/026-000 231-708/027-000 231-708/031-000 231-708/037-000 231-709/008-000 231-709/026-000 231-709/027-000 231-709/031-000 231-709/037-000 231-710/008-000 231-710/026-000 231-710/027-000 231-710/031-000 231-710/037-000 231-711/008-000 231-711/026-000 231-711/027-000 231-711/031-000 231-711/037-000 231-712/008-000 231-712/026-000 231-712/027-000 231-712/031-000 231-712/037-000 231-732/001-000 231-733/001-000 231-734/001-000 231-735/001-000 231-736/001-000 231-737/001-000 231-738/001-000 231-739/001-000 231-740/001-000 231-741/001-000 231-742/001-000 231-762/001-000 231-763/001-000 231-764/001-000 231-765/001-000 231-766/001-000 231-767/001-000 231-768/001-000 231-769/001-000 231-770/001-000 231-771/001-000 231-772/001-000 231-832/001-000 231-832/001-000/105-604 231-832/001-000/105-604/997-405 231-833/001-000 231-833/001-000/105-604 231-833/001-000/105-604/997-407 231-834/001-000 231-834/001-000/105-604 231-834/001-000/105-604/997-407 231-835/001-000 231-835/001-000/105-604 231-835/001-000/105-604/997-407 231-836/001-000 231-836/001-000/105-604 231-836/001-000/105-604/997-409 231-837/001-000 231-837/001-000/105-604 231-837/001-000/105-604/997-409 231-838/001-000 231-838/001-000/105-604 231-838/001-000/105-604/997-409 231-839/001-000 231-839/001-000/105-604 231-839/001-000/105-604/997-409 231-840/001-000 231-840/001-000/105-604 231-840/040-000 231-841/001-000 231-841/001-000/105-604 231-842/001-000 231-842/001-000/105-604 231-843/001-000 231-846/001-000 231-862/001-000 231-862/001-000/105-604 231-862/001-000/105-604/997-405 231-863/001-000 231-863/001-000/105-604 231-863/001-000/105-604/997-407 231-864/001-000 231-864/001-000/105-604 231-864/001-000/105-604/997-407 231-865/001-000 231-865/001-000/105-604 231-865/001-000/105-604/997-407 231-866/001-000 231-866/001-000/105-604
231770/001000, 231 770/001 000
