Datasheet Wago 231-833/001-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; угловые; Шаг контактов 7,5 мм; 3-пол.
![]() 14 предложений от 6 поставщиков THT MALE HEADER; 1.0 X 1.0 MM SO | |||
231-833/001-000 Wago | 145 ₽ | ||
231-833/001-000 | от 216 ₽ | ||
231-833/001-000 Wago | 545 ₽ | ||
231-833/001-000 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 12 mm / 0.472 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.026 MJ |
GTIN | 4044918868068 |
Height | 12.2 mm / 0.48 inch |
Height from the surface | 8.4 mm / 0.331 inch |
Material group | I |
Mismating protection | No |
Number of Poles | 3 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1 mm |
Solder pin length | 3.8 мм |
Total number of potentials | 3 |
Вес | 1.254 г |
Ширина | 23.2 mm / 0.913 inch |
Серия: 231 (100 из 1349)
- 231-708/008-000 231-708/026-000 231-708/027-000 231-708/031-000 231-708/037-000 231-709/008-000 231-709/026-000 231-709/027-000 231-709/031-000 231-709/037-000 231-710/008-000 231-710/026-000 231-710/027-000 231-710/031-000 231-710/037-000 231-711/008-000 231-711/026-000 231-711/027-000 231-711/031-000 231-711/037-000 231-712/008-000 231-712/026-000 231-712/027-000 231-712/031-000 231-712/037-000 231-732/001-000 231-733/001-000 231-734/001-000 231-735/001-000 231-736/001-000 231-737/001-000 231-738/001-000 231-739/001-000 231-740/001-000 231-741/001-000 231-742/001-000 231-762/001-000 231-763/001-000 231-764/001-000 231-765/001-000 231-766/001-000 231-767/001-000 231-768/001-000 231-769/001-000 231-770/001-000 231-771/001-000 231-772/001-000 231-832/001-000 231-832/001-000/105-604 231-832/001-000/105-604/997-405 231-833/001-000 231-833/001-000/105-604 231-833/001-000/105-604/997-407 231-834/001-000 231-834/001-000/105-604 231-834/001-000/105-604/997-407 231-835/001-000 231-835/001-000/105-604 231-835/001-000/105-604/997-407 231-836/001-000 231-836/001-000/105-604 231-836/001-000/105-604/997-409 231-837/001-000 231-837/001-000/105-604 231-837/001-000/105-604/997-409 231-838/001-000 231-838/001-000/105-604 231-838/001-000/105-604/997-409 231-839/001-000 231-839/001-000/105-604 231-839/001-000/105-604/997-409 231-840/001-000 231-840/001-000/105-604 231-840/040-000 231-841/001-000 231-841/001-000/105-604 231-842/001-000 231-842/001-000/105-604 231-843/001-000 231-846/001-000 231-862/001-000 231-862/001-000/105-604 231-862/001-000/105-604/997-405 231-863/001-000 231-863/001-000/105-604 231-863/001-000/105-604/997-407 231-864/001-000 231-864/001-000/105-604 231-864/001-000/105-604/997-407 231-865/001-000 231-865/001-000/105-604 231-865/001-000/105-604/997-407 231-866/001-000 231-866/001-000/105-604 231-866/001-000/105-604/997-409 231-867/001-000 231-867/001-000/105-604 231-867/001-000/105-604/997-409 231-868/001-000 231-868/001-000/105-604
231833/001000, 231 833/001 000
