Datasheet Wago 231-866/001-000/105-604 — Даташит
Вилка под пайку THR; 1.2 x 1.2 mm solder pin; угловые; Шаг контактов 7,5 мм; 6-пол.
| THT MALE HEADER; 1.2 X 1.2 MM SO | |||
| 231-866/001-000 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 12 mm / 0.472 inch |
| GTIN | 4045454901349 |
| Height | 10.8 mm / 0.425 inch |
| Height from the surface | 8.4 mm / 0.331 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 6 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THR |
| Pin spacing | 7.5 mm (0.295 inch) |
| Plated through-hole diameter (THR) | 1.7 (+ 0.1) мм |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1.2 x 1.2 mm |
| Solder pin length | 2.4 мм |
| Total number of potentials | 6 |
| Вес | 3.088 г |
| Ширина | 45.5 mm / 1.791 inch |
Серия: 231 (100 из 1349)
- 231-766/001-000 231-767/001-000 231-768/001-000 231-769/001-000 231-770/001-000 231-771/001-000 231-772/001-000 231-832/001-000 231-832/001-000/105-604 231-832/001-000/105-604/997-405 231-833/001-000 231-833/001-000/105-604 231-833/001-000/105-604/997-407 231-834/001-000 231-834/001-000/105-604 231-834/001-000/105-604/997-407 231-835/001-000 231-835/001-000/105-604 231-835/001-000/105-604/997-407 231-836/001-000 231-836/001-000/105-604 231-836/001-000/105-604/997-409 231-837/001-000 231-837/001-000/105-604 231-837/001-000/105-604/997-409 231-838/001-000 231-838/001-000/105-604 231-838/001-000/105-604/997-409 231-839/001-000 231-839/001-000/105-604 231-839/001-000/105-604/997-409 231-840/001-000 231-840/001-000/105-604 231-840/040-000 231-841/001-000 231-841/001-000/105-604 231-842/001-000 231-842/001-000/105-604 231-843/001-000 231-846/001-000 231-862/001-000 231-862/001-000/105-604 231-862/001-000/105-604/997-405 231-863/001-000 231-863/001-000/105-604 231-863/001-000/105-604/997-407 231-864/001-000 231-864/001-000/105-604 231-864/001-000/105-604/997-407 231-865/001-000 231-865/001-000/105-604 231-865/001-000/105-604/997-407 231-866/001-000 231-866/001-000/105-604 231-866/001-000/105-604/997-409 231-867/001-000 231-867/001-000/105-604 231-867/001-000/105-604/997-409 231-868/001-000 231-868/001-000/105-604 231-868/001-000/105-604/997-409 231-869/001-000 231-869/001-000/105-604 231-869/001-000/105-604/997-409 231-870/001-000 231-870/001-000/105-604 231-870/040-000 231-871/001-000 231-871/001-000/105-604 231-872/001-000 231-872/001-000/105-604 231-873/001-000 231-876/001-000 231-902 231-903 231-905 231-907 231-910 231-932/001-000 231-933/001-000 231-934/001-000 231-935/001-000 231-936/001-000 231-937/001-000 231-938/001-000 231-939/001-000 231-940/001-000 231-941/001-000 231-942/001-000 231-962/001-000 231-963/001-000 231-964/001-000 231-965/001-000 231-966/001-000 231-967/001-000 231-968/001-000 231-969/001-000 231-970/001-000 231-971/001-000 231-972/001-000
231866/001000/105604, 231 866/001 000/105 604
