Datasheet Wago 231-2110/037-000 — Даташит
2-проводная розетка; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 5 мм; 10-пол.
2-CONDUCTOR FEMALE CONNECTOR; LO | |||
| 231-2110/037-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 29.8 mm / 1.173 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.409 MJ |
| GTIN | 4044918563178 |
| Height | 20.8 mm / 0.819 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 20 |
| Total number of potentials | 10 |
| Вес | 23.95 г |
| Ширина | 66.55 mm / 2.62 inch |
Серия: 231 (100 из 1349)
- 231-205/026-000 231-205/031-000 231-205/037-000 231-206/008-000 231-206/026-000 231-206/027-000 231-206/031-000 231-206/037-000 231-207/008-000 231-207/026-000 231-207/027-000 231-207/031-000 231-207/037-000 231-208/008-000 231-208/026-000 231-208/027-000 231-208/031-000 231-208/037-000 231-209/008-000 231-209/026-000 231-209/027-000 231-209/031-000 231-209/037-000 231-210/008-000 231-210/026-000 231-210/027-000 231-210/031-000 231-210/037-000 231-2102/026-000 231-2102/037-000 231-2103/026-000 231-2103/037-000 231-2104/026-000 231-2104/037-000 231-2105/026-000 231-2105/037-000 231-2106/026-000 231-2106/037-000 231-2107/026-000 231-2107/037-000 231-2108/026-000 231-2108/037-000 231-2109/026-000 231-2109/037-000 231-211/008-000 231-211/026-000 231-211/027-000 231-211/031-000 231-211/037-000 231-2110/026-000 231-2110/037-000 231-2111/026-000 231-2111/037-000 231-2112/026-000 231-2112/037-000 231-2113/026-000 231-2113/037-000 231-2114/026-000 231-2114/037-000 231-2115/026-000 231-2115/037-000 231-2116/026-000 231-2116/037-000 231-212/008-000 231-212/026-000 231-212/027-000 231-212/031-000 231-212/037-000 231-213/008-000 231-213/026-000 231-213/027-000 231-213/031-000 231-213/037-000 231-216/008-000 231-216/026-000 231-216/027-000 231-216/031-000 231-216/037-000 231-2202/026-000 231-2202/037-000 231-2203/026-000 231-2203/037-000 231-2204/026-000 231-2204/037-000 231-2205/026-000 231-2205/037-000 231-2206/026-000 231-2206/037-000 231-2207/026-000 231-2207/037-000 231-2208/026-000 231-2208/037-000 231-2209/026-000 231-2209/037-000 231-2210/026-000 231-2210/037-000 231-2211/026-000 231-2211/037-000 231-2212/026-000 231-2212/037-000
2312110/037000, 231 2110/037 000
