Datasheet Wago 231-2304/026-000 — Даташит
2-проводная розетка; 2,5 мм²; Шаг контактов 5,08 мм; 4-пол.
| 2-CONDUCTOR FEMALE CONNECTOR; 2. | |||
| 231-2304/026-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 26.45 mm / 1.041 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.139 MJ |
| GTIN | 4044918564427 |
| Height | 20.8 mm / 0.819 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 4 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 8 |
| Total number of potentials | 4 |
| Вес | 8.8 г |
| Ширина | 20.16 mm / 0.794 inch |
Серия: 231 (100 из 1349)
- 231-2113/037-000 231-2114/026-000 231-2114/037-000 231-2115/026-000 231-2115/037-000 231-2116/026-000 231-2116/037-000 231-212/008-000 231-212/026-000 231-212/027-000 231-212/031-000 231-212/037-000 231-213/008-000 231-213/026-000 231-213/027-000 231-213/031-000 231-213/037-000 231-216/008-000 231-216/026-000 231-216/027-000 231-216/031-000 231-216/037-000 231-2202/026-000 231-2202/037-000 231-2203/026-000 231-2203/037-000 231-2204/026-000 231-2204/037-000 231-2205/026-000 231-2205/037-000 231-2206/026-000 231-2206/037-000 231-2207/026-000 231-2207/037-000 231-2208/026-000 231-2208/037-000 231-2209/026-000 231-2209/037-000 231-2210/026-000 231-2210/037-000 231-2211/026-000 231-2211/037-000 231-2212/026-000 231-2212/037-000 231-2302/026-000 231-2302/037-000 231-2302/107-000 231-2303/026-000 231-2303/037-000 231-2303/107-000 231-2304/026-000 231-2304/037-000 231-2304/107-000 231-2305/026-000 231-2305/037-000 231-2305/107-000 231-2306/026-000 231-2306/037-000 231-2306/107-000 231-2307/026-000 231-2307/037-000 231-2307/107-000 231-2308/026-000 231-2308/037-000 231-2308/107-000 231-2309/026-000 231-2309/037-000 231-2309/107-000 231-2310/026-000 231-2310/037-000 231-2310/107-000 231-2311/026-000 231-2311/037-000 231-2312/026-000 231-2312/037-000 231-2312/107-000 231-2313/026-000 231-2313/037-000 231-2314/026-000 231-2314/037-000 231-2314/107-000 231-2315/026-000 231-2315/037-000 231-2315/107-000 231-2316/026-000 231-2316/037-000 231-2316/107-000 231-232/001-000 231-232/001-000/105-604 231-232/001-000/105-604/997-405 231-233/001-000 231-233/001-000/105-604 231-233/001-000/105-604/997-407 231-234/001-000 231-234/001-000/105-604 231-234/001-000/105-604/997-407 231-235/001-000 231-235/001-000/105-604 231-235/001-000/105-604/997-407 231-236/001-000
2312304/026000, 231 2304/026 000
