Datasheet Wago 231-2712/037-000 — Даташит
2-проводная розетка; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 7,62 мм; 12-пол.
| 2-CONDUCTOR FEMALE CONNECTOR; LO | |||
| 231-2712/037-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 29.8 mm / 1.173 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.68 MJ |
| GTIN | 4044918565820 |
| Height | 20.8 mm / 0.819 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 12 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.62 mm (0.3 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 24 |
| Total number of potentials | 12 |
| Вес | 35.058 г |
| Ширина | 105.25 mm / 4.144 inch |
Серия: 231 (100 из 1349)
- 231-262/001-000/105-604 231-262/001-000/105-604/997-405 231-263/001-000 231-263/001-000/105-604 231-263/001-000/105-604/997-407 231-264/001-000 231-264/001-000/105-604 231-264/001-000/105-604/997-407 231-265/001-000 231-265/001-000/105-604 231-265/001-000/105-604/997-407 231-266/001-000 231-266/001-000/105-604 231-266/001-000/105-604/997-409 231-267/001-000 231-267/001-000/105-604 231-267/001-000/105-604/997-409 231-268/001-000 231-268/001-000/105-604 231-268/001-000/105-604/997-409 231-269/001-000 231-269/001-000/105-604 231-269/001-000/105-604/997-409 231-270/001-000 231-270/001-000/105-604 231-270/040-000 231-270/046-000 231-2702/026-000 231-2702/037-000 231-2703/026-000 231-2703/037-000 231-2704/026-000 231-2704/037-000 231-2705/026-000 231-2705/037-000 231-2706/026-000 231-2706/037-000 231-2707/026-000 231-2707/037-000 231-2708/026-000 231-2708/037-000 231-2709/026-000 231-2709/037-000 231-271/001-000 231-271/001-000/105-604 231-2710/026-000 231-2710/037-000 231-2711/026-000 231-2711/037-000 231-2712/026-000 231-2712/037-000 231-272/001-000 231-272/001-000/105-604 231-273/001-000 231-276/001-000 231-300 231-302/008-000 231-302/026-000 231-302/031-000 231-302/037-000 231-302/102-000 231-302/107-000 231-303/008-000 231-303/026-000 231-303/031-000 231-303/037-000 231-303/102-000 231-303/107-000 231-304/008-000 231-304/026-000 231-304/031-000 231-304/037-000 231-304/102-000 231-304/107-000 231-305/008-000 231-305/026-000 231-305/031-000 231-305/037-000 231-305/102-000 231-305/107-000 231-306/008-000 231-306/026-000 231-306/027-000 231-306/031-000 231-306/037-000 231-306/102-000 231-306/107-000 231-307/008-000 231-307/026-000 231-307/027-000 231-307/031-000 231-307/037-000 231-307/102-000 231-307/107-000 231-308/008-000 231-308/026-000 231-308/027-000 231-308/031-000 231-308/037-000 231-308/102-000
2312712/037000, 231 2712/037 000
