Datasheet Wago 232-140/005-000/039-000 — Даташит
Розетка для клемм на рейку; прямые; Фиксирующий рычаг; Шаг контактов 5 мм; 10-пол.
| FEMALE CONNECTOR FOR RAIL-MOUNT | |||
| 232-140/005-000/039-000 Wago | по запросу | ||
| Цвет | gray |
| Connector connection type | for front-entry wiring terminal block |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 11.6 mm / 0.457 inch |
| Fire load | 0.211 MJ |
| GTIN | 4044918570930 |
| Height | 36.1 mm / 1.421 inch |
| Height from the surface | 21.6 mm / 0.85 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 10 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Steckrichtung zur Reihenklemme | 90 ° |
| Total number of potentials | 10 |
| Вес | 11.35 г |
| Ширина | 65.8 mm / 2.591 inch |
Серия: 232 (100 из 896)
- 232-132 232-132/005-000 232-132/005-000/039-000 232-132/031-000 232-132/039-000 232-132/047-000 232-133 232-133/005-000 232-133/005-000/039-000 232-133/031-000 232-133/039-000 232-133/047-000 232-134 232-134/005-000 232-134/005-000/039-000 232-134/031-000 232-134/039-000 232-134/047-000 232-135 232-135/005-000 232-135/005-000/039-000 232-135/031-000 232-135/039-000 232-135/047-000 232-136 232-136/005-000 232-136/005-000/039-000 232-136/031-000 232-136/039-000 232-136/047-000 232-137 232-137/005-000 232-137/005-000/039-000 232-137/031-000 232-137/039-000 232-137/047-000 232-138 232-138/005-000 232-138/005-000/039-000 232-138/031-000 232-138/039-000 232-138/047-000 232-139 232-139/005-000 232-139/005-000/039-000 232-139/031-000 232-139/039-000 232-139/047-000 232-140 232-140/005-000 232-140/005-000/039-000 232-140/031-000 232-140/039-000 232-140/047-000 232-141 232-141/005-000 232-141/005-000/039-000 232-141/031-000 232-141/039-000 232-141/047-000 232-142 232-142/005-000 232-142/005-000/039-000 232-142/031-000 232-142/039-000 232-142/047-000 232-143 232-143/005-000 232-143/005-000/039-000 232-143/031-000 232-143/039-000 232-143/047-000 232-144 232-144/005-000 232-144/005-000/039-000 232-144/031-000 232-144/039-000 232-144/047-000 232-145 232-145/005-000 232-145/005-000/039-000 232-145/031-000 232-145/039-000 232-145/047-000 232-146 232-146/005-000 232-146/005-000/039-000 232-146/031-000 232-146/039-000 232-146/047-000 232-147 232-147/005-000 232-147/005-000/039-000 232-147/031-000 232-147/039-000 232-147/047-000 232-148 232-148/005-000 232-148/005-000/039-000 232-148/031-000
232140/005000/039000, 232 140/005 000/039 000
