Datasheet Wago 232-143/047-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; Проходной фланец; Шаг контактов 5 мм; 13-пол.
| THT FEMALE HEADER; 0.6 X 1.0 MM | |||
| 232-143/047-000 Wago | по запросу | ||
| Цвет | gray |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 11.6 mm / 0.457 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.237 MJ |
| GTIN | 4044918623599 |
| Height | 23.25 mm / 0.915 inch |
| Height from the surface | 18.25 mm / 0.719 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 13 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 13 |
| Type of mounting | Flush mounting Panel mounting |
| Вес | 12.93 г |
| Ширина | 79.8 mm / 3.142 inch |
Серия: 232 (100 из 896)
- 232-135/031-000 232-135/039-000 232-135/047-000 232-136 232-136/005-000 232-136/005-000/039-000 232-136/031-000 232-136/039-000 232-136/047-000 232-137 232-137/005-000 232-137/005-000/039-000 232-137/031-000 232-137/039-000 232-137/047-000 232-138 232-138/005-000 232-138/005-000/039-000 232-138/031-000 232-138/039-000 232-138/047-000 232-139 232-139/005-000 232-139/005-000/039-000 232-139/031-000 232-139/039-000 232-139/047-000 232-140 232-140/005-000 232-140/005-000/039-000 232-140/031-000 232-140/039-000 232-140/047-000 232-141 232-141/005-000 232-141/005-000/039-000 232-141/031-000 232-141/039-000 232-141/047-000 232-142 232-142/005-000 232-142/005-000/039-000 232-142/031-000 232-142/039-000 232-142/047-000 232-143 232-143/005-000 232-143/005-000/039-000 232-143/031-000 232-143/039-000 232-143/047-000 232-144 232-144/005-000 232-144/005-000/039-000 232-144/031-000 232-144/039-000 232-144/047-000 232-145 232-145/005-000 232-145/005-000/039-000 232-145/031-000 232-145/039-000 232-145/047-000 232-146 232-146/005-000 232-146/005-000/039-000 232-146/031-000 232-146/039-000 232-146/047-000 232-147 232-147/005-000 232-147/005-000/039-000 232-147/031-000 232-147/039-000 232-147/047-000 232-148 232-148/005-000 232-148/005-000/039-000 232-148/031-000 232-148/039-000 232-148/047-000 232-149 232-149/005-000 232-149/005-000/039-000 232-149/031-000 232-149/039-000 232-149/047-000 232-150 232-150/005-000 232-150/005-000/039-000 232-150/031-000 232-150/039-000 232-150/047-000 232-151 232-151/031-000 232-151/039-000 232-151/047-000 232-152 232-152/031-000 232-152/039-000
232143/047000, 232 143/047 000
