Datasheet Wago 232-150 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; Шаг контактов 5 мм; 20-пол.
10 предложений от 10 поставщиков Axial Lead and Cartridge Fuses - Designed to METI Standard | |||
OSTHA232150 On Shore Technology | 380 ₽ | ||
OSTYE232150 | по запросу | ||
Q2-32150 | по запросу | ||
OSTYP232150 On Shore Technology | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 11.6 mm / 0.457 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fire load | 0.323 MJ |
GTIN | 4044918578646 |
Height | 23.25 mm / 0.915 inch |
Height from the surface | 18.25 mm / 0.719 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 20 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 20 |
Вес | 18.482 г |
Ширина | 101.5 mm / 3.996 inch |
Серия: 232 (100 из 896)
- 232-141/039-000 232-141/047-000 232-142 232-142/005-000 232-142/005-000/039-000 232-142/031-000 232-142/039-000 232-142/047-000 232-143 232-143/005-000 232-143/005-000/039-000 232-143/031-000 232-143/039-000 232-143/047-000 232-144 232-144/005-000 232-144/005-000/039-000 232-144/031-000 232-144/039-000 232-144/047-000 232-145 232-145/005-000 232-145/005-000/039-000 232-145/031-000 232-145/039-000 232-145/047-000 232-146 232-146/005-000 232-146/005-000/039-000 232-146/031-000 232-146/039-000 232-146/047-000 232-147 232-147/005-000 232-147/005-000/039-000 232-147/031-000 232-147/039-000 232-147/047-000 232-148 232-148/005-000 232-148/005-000/039-000 232-148/031-000 232-148/039-000 232-148/047-000 232-149 232-149/005-000 232-149/005-000/039-000 232-149/031-000 232-149/039-000 232-149/047-000 232-150 232-150/005-000 232-150/005-000/039-000 232-150/031-000 232-150/039-000 232-150/047-000 232-151 232-151/031-000 232-151/039-000 232-151/047-000 232-152 232-152/031-000 232-152/039-000 232-152/047-000 232-153 232-153/031-000 232-153/039-000 232-153/047-000 232-154 232-154/031-000 232-154/047-000 232-162 232-162/031-000 232-162/039-000 232-162/047-000 232-163 232-163/031-000 232-163/039-000 232-163/047-000 232-164 232-164/031-000 232-164/039-000 232-164/047-000 232-165 232-165/031-000 232-165/039-000 232-165/047-000 232-166 232-166/031-000 232-166/039-000 232-166/047-000 232-167 232-167/031-000 232-167/039-000 232-167/047-000 232-168 232-168/031-000 232-168/039-000 232-168/047-000 232-169
