Оптопары и оптореле Megawin
Datasheet Wago 232-167 — Даташит
Серия232
Модель232-167
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; Шаг контактов 5,08 мм; 7-пол.
Axial Lead and Cartridge Fuses - Designed to METI Standard
TradeElectronics
Littelfuse
Wago 232-167
Цветorange
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина11.6 mm / 0.457 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.103 MJ
GTIN4044918578745
Height23.25 mm / 0.915 inch
Height from the surface18.25 mm / 0.719 inch
Material groupI
Mismating protectionNo
Number of Poles7
Number of levels1
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current12 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of connection points7
Total number of potentials7
Вес6.15 г
Ширина37.06 mm / 1.459 inch
На английском языке: Datasheet Wago 232-167
