Datasheet Wago 232-173/031-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; зажимное кольцо; Шаг контактов 5,08 мм; 13-пол.
Купить 232-173 на РадиоЛоцман.Цены — от 287 до 51 033 ₽ 5 предложений от 5 поставщиков Axial Lead and Cartridge Fuses - Designed to METI Standard | |||
1-23217-3 TE Connectivity | 287 ₽ | ||
1-23217-3 TE Connectivity | 291 ₽ | ||
232-173 Littelfuse | по запросу | ||
232-173 Wago | по запросу |
Цвет | orange |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 11.6 mm / 0.457 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
GTIN | 4055143577625 |
Height | 23.25 mm / 0.915 inch |
Height from the surface | 18.25 mm / 0.719 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 13 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of connection points | 13 |
Total number of potentials | 13 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 11.914 г |
Ширина | 80.84 mm / 3.183 inch |
Серия: 232 (100 из 896)
- 232-153/039-000 232-153/047-000 232-154 232-154/031-000 232-154/047-000 232-162 232-162/031-000 232-162/039-000 232-162/047-000 232-163 232-163/031-000 232-163/039-000 232-163/047-000 232-164 232-164/031-000 232-164/039-000 232-164/047-000 232-165 232-165/031-000 232-165/039-000 232-165/047-000 232-166 232-166/031-000 232-166/039-000 232-166/047-000 232-167 232-167/031-000 232-167/039-000 232-167/047-000 232-168 232-168/031-000 232-168/039-000 232-168/047-000 232-169 232-169/031-000 232-169/039-000 232-169/047-000 232-170 232-170/031-000 232-170/039-000 232-170/047-000 232-171 232-171/031-000 232-171/039-000 232-171/047-000 232-172 232-172/031-000 232-172/039-000 232-172/047-000 232-173 232-173/031-000 232-173/039-000 232-173/047-000 232-174 232-174/031-000 232-174/039-000 232-174/047-000 232-175 232-175/031-000 232-175/039-000 232-175/047-000 232-176 232-176/031-000 232-176/039-000 232-176/047-000 232-177 232-177/031-000 232-177/039-000 232-177/047-000 232-178 232-178/031-000 232-178/039-000 232-178/047-000 232-179 232-179/031-000 232-179/039-000 232-179/047-000 232-180 232-180/031-000 232-180/039-000 232-180/047-000 232-181 232-181/031-000 232-181/039-000 232-181/047-000 232-182 232-182/031-000 232-182/039-000 232-182/047-000 232-183 232-183/031-000 232-183/039-000 232-183/047-000 232-184 232-184/031-000 232-184/039-000 232-184/047-000 232-202/026-000 232-203/026-000 232-204/026-000
232173/031000, 232 173/031 000
