Datasheet Wago 232-175/047-000 — Даташит
Серия232
Модель232-175/047-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; Проходной фланец; Шаг контактов 5,08 мм; 15-пол.
Axial Lead and Cartridge Fuses - Designed to METI Standard
ТаймЧипс
Littelfuse
Цветorange
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина11.6 mm / 0.457 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.241 MJ
GTIN4050821637844
Height23.25 mm / 0.915 inch
Height from the surface18.25 mm / 0.719 inch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles15
Number of levels1
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current12 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of connection points15
Total number of potentials15
Type of mountingFlush mounting Panel mounting
Вес13.918 г
Ширина91 mm / 3.583 inch
232175/047000, 232 175/047 000
На английском языке: Datasheet Wago 232-175/047-000
