Datasheet Wago 232-180/031-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; зажимное кольцо; Шаг контактов 5,08 мм; 20-пол.
Купить 232-180 на РадиоЛоцман.Цены — от 25 до 16 420 ₽ 7 предложений от 7 поставщиков Клеммные Блоки, Conn Term Block 23POS 7.5mm | |||
| OSTTT232180 | 432 ₽ | ||
| OSTVT232180 | по запросу | ||
| OSTTT232180 On Shore Technology | по запросу | ||
| OSTVT232180 On Shore Technology | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 11.6 mm / 0.457 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.302 MJ |
| GTIN | 4044918624411 |
| Height | 23.25 mm / 0.915 inch |
| Height from the surface | 18.25 mm / 0.719 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 20 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of connection points | 20 |
| Total number of potentials | 20 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 17.9 г |
| Ширина | 116.4 mm / 4.583 inch |
Серия: 232 (100 из 896)
- 232-167/047-000 232-168 232-168/031-000 232-168/039-000 232-168/047-000 232-169 232-169/031-000 232-169/039-000 232-169/047-000 232-170 232-170/031-000 232-170/039-000 232-170/047-000 232-171 232-171/031-000 232-171/039-000 232-171/047-000 232-172 232-172/031-000 232-172/039-000 232-172/047-000 232-173 232-173/031-000 232-173/039-000 232-173/047-000 232-174 232-174/031-000 232-174/039-000 232-174/047-000 232-175 232-175/031-000 232-175/039-000 232-175/047-000 232-176 232-176/031-000 232-176/039-000 232-176/047-000 232-177 232-177/031-000 232-177/039-000 232-177/047-000 232-178 232-178/031-000 232-178/039-000 232-178/047-000 232-179 232-179/031-000 232-179/039-000 232-179/047-000 232-180 232-180/031-000 232-180/039-000 232-180/047-000 232-181 232-181/031-000 232-181/039-000 232-181/047-000 232-182 232-182/031-000 232-182/039-000 232-182/047-000 232-183 232-183/031-000 232-183/039-000 232-183/047-000 232-184 232-184/031-000 232-184/039-000 232-184/047-000 232-202/026-000 232-203/026-000 232-204/026-000 232-205/026-000 232-206/026-000 232-207/026-000 232-208/026-000 232-209/026-000 232-210/026-000 232-211/026-000 232-212/026-000 232-213/026-000 232-214/026-000 232-215/026-000 232-216/026-000 232-217/026-000 232-218/026-000 232-219/026-000 232-220/026-000 232-221/026-000 232-222/026-000 232-223/026-000 232-224/026-000 232-232 232-232/005-000 232-232/005-000/039-000 232-232/031-000 232-232/039-000 232-232/047-000 232-233 232-233/005-000
232180/031000, 232 180/031 000
