Datasheet Wago 232-182/047-000 — Даташит
Серия232
Модель232-182/047-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; Проходной фланец; Шаг контактов 5,08 мм; 22-пол.
Axial Lead and Cartridge Fuses - Designed to METI Standard
LifeElectronics
232-182-KB
Littelfuse
Цветorange
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина11.6 mm / 0.457 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.339 MJ
GTIN4050821637912
Height23.25 mm / 0.915 inch
Height from the surface18.25 mm / 0.719 inch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles22
Number of levels1
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current12 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of connection points22
Total number of potentials22
Type of mountingFlush mounting Panel mounting
Вес19.938 г
Ширина126.56 mm / 4.983 inch
Серия: 232 (100 из 896)
232182/047000, 232 182/047 000
На английском языке: Datasheet Wago 232-182/047-000
