Datasheet Wago 232-236/005-000/039-000 — Даташит
Розетка для клемм на рейку; угловые; Фиксирующий рычаг; Шаг контактов 5 мм; 6-пол.
| FEMALE CONNECTOR FOR RAIL-MOUNT | |||
| 232-236/005-000 Wago | по запросу | ||
| Цвет | gray |
| Connector connection type | for front-entry wiring terminal block |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 11.6 mm / 0.457 inch |
| Fire load | 0.137 MJ |
| GTIN | 4044918572002 |
| Height | 26.1 mm / 1.028 inch |
| Height from the surface | 11.6 mm / 0.457 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 6 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Total number of potentials | 6 |
| Вес | 7.192 г |
| Ширина | 45.8 mm / 1.803 inch |
Серия: 232 (100 из 896)
- 232-184/047-000 232-202/026-000 232-203/026-000 232-204/026-000 232-205/026-000 232-206/026-000 232-207/026-000 232-208/026-000 232-209/026-000 232-210/026-000 232-211/026-000 232-212/026-000 232-213/026-000 232-214/026-000 232-215/026-000 232-216/026-000 232-217/026-000 232-218/026-000 232-219/026-000 232-220/026-000 232-221/026-000 232-222/026-000 232-223/026-000 232-224/026-000 232-232 232-232/005-000 232-232/005-000/039-000 232-232/031-000 232-232/039-000 232-232/047-000 232-233 232-233/005-000 232-233/005-000/039-000 232-233/031-000 232-233/039-000 232-233/047-000 232-234 232-234/005-000 232-234/005-000/039-000 232-234/031-000 232-234/039-000 232-234/047-000 232-235 232-235/005-000 232-235/005-000/039-000 232-235/031-000 232-235/039-000 232-235/047-000 232-236 232-236/005-000 232-236/005-000/039-000 232-236/031-000 232-236/039-000 232-236/047-000 232-237 232-237/005-000 232-237/005-000/039-000 232-237/031-000 232-237/039-000 232-237/047-000 232-238 232-238/005-000 232-238/031-000 232-238/039-000 232-238/047-000 232-239 232-239/005-000 232-239/005-000/039-000 232-239/031-000 232-239/039-000 232-239/047-000 232-240 232-240/005-000 232-240/005-000/039-000 232-240/031-000 232-240/039-000 232-240/047-000 232-241 232-241/005-000 232-241/005-000/039-000 232-241/031-000 232-241/039-000 232-241/047-000 232-242 232-242/005-000 232-242/005-000/039-000 232-242/031-000 232-242/039-000 232-242/047-000 232-243 232-243/005-000 232-243/005-000/039-000 232-243/031-000 232-243/039-000 232-243/047-000 232-244 232-244/005-000 232-244/005-000/039-000 232-244/031-000 232-244/039-000
232236/005000/039000, 232 236/005 000/039 000
