Datasheet Wago 232-238/047-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Проходной фланец; Шаг контактов 5 мм; 8-пол.
![]() 15 предложений от 8 поставщиков Axial Lead and Cartridge Fuses - Designed to METI Standard | |||
232-238 Wago | от 889 ₽ | ||
232-238 | от 896 ₽ | ||
232-238 Wago | 1 479 ₽ | ||
232-238 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 18.25 mm / 0.719 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fire load | 0.157 MJ |
GTIN | 4044918579230 |
Height | 16.6 mm / 0.654 inch |
Height from the surface | 11.6 mm / 0.457 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 8 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 8 |
Type of mounting | Flush mounting Panel mounting |
Вес | 8.33 г |
Ширина | 54.8 mm / 2.157 inch |
Серия: 232 (100 из 896)
- 232-215/026-000 232-216/026-000 232-217/026-000 232-218/026-000 232-219/026-000 232-220/026-000 232-221/026-000 232-222/026-000 232-223/026-000 232-224/026-000 232-232 232-232/005-000 232-232/005-000/039-000 232-232/031-000 232-232/039-000 232-232/047-000 232-233 232-233/005-000 232-233/005-000/039-000 232-233/031-000 232-233/039-000 232-233/047-000 232-234 232-234/005-000 232-234/005-000/039-000 232-234/031-000 232-234/039-000 232-234/047-000 232-235 232-235/005-000 232-235/005-000/039-000 232-235/031-000 232-235/039-000 232-235/047-000 232-236 232-236/005-000 232-236/005-000/039-000 232-236/031-000 232-236/039-000 232-236/047-000 232-237 232-237/005-000 232-237/005-000/039-000 232-237/031-000 232-237/039-000 232-237/047-000 232-238 232-238/005-000 232-238/031-000 232-238/039-000 232-238/047-000 232-239 232-239/005-000 232-239/005-000/039-000 232-239/031-000 232-239/039-000 232-239/047-000 232-240 232-240/005-000 232-240/005-000/039-000 232-240/031-000 232-240/039-000 232-240/047-000 232-241 232-241/005-000 232-241/005-000/039-000 232-241/031-000 232-241/039-000 232-241/047-000 232-242 232-242/005-000 232-242/005-000/039-000 232-242/031-000 232-242/039-000 232-242/047-000 232-243 232-243/005-000 232-243/005-000/039-000 232-243/031-000 232-243/039-000 232-243/047-000 232-244 232-244/005-000 232-244/005-000/039-000 232-244/031-000 232-244/039-000 232-244/047-000 232-245 232-245/005-000 232-245/005-000/039-000 232-245/031-000 232-245/039-000 232-245/047-000 232-246 232-246/005-000 232-246/005-000/039-000 232-246/031-000 232-246/039-000 232-246/047-000 232-247
232238/047000, 232 238/047 000
