Datasheet Wago 232-241/031-000 — Даташит
Розетка под пайку THT
![]() 6 предложений от 6 поставщиков Соединители Плата-плата, Conn Wire to Board HDR 24POS 2.54mm Solder ST Thru-Hole Bag | |||
22-23-2241 Molex | 109 ₽ | ||
23-224-1 | по запросу | ||
XLB232241 | по запросу | ||
232241-001 | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 18.25 mm / 0.719 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
GTIN | 4055143759243 |
Height | 16.6 mm / 0.654 inch |
Height from the surface | 11.6 mm / 0.457 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 11 |
Number of levels | 1 |
PCB contact | THT |
Packaging type | BOX |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 11 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 10.766 г |
Ширина | 69.8 mm / 2.748 inch |
Серия: 232 (100 из 896)
- 232-233 232-233/005-000 232-233/005-000/039-000 232-233/031-000 232-233/039-000 232-233/047-000 232-234 232-234/005-000 232-234/005-000/039-000 232-234/031-000 232-234/039-000 232-234/047-000 232-235 232-235/005-000 232-235/005-000/039-000 232-235/031-000 232-235/039-000 232-235/047-000 232-236 232-236/005-000 232-236/005-000/039-000 232-236/031-000 232-236/039-000 232-236/047-000 232-237 232-237/005-000 232-237/005-000/039-000 232-237/031-000 232-237/039-000 232-237/047-000 232-238 232-238/005-000 232-238/031-000 232-238/039-000 232-238/047-000 232-239 232-239/005-000 232-239/005-000/039-000 232-239/031-000 232-239/039-000 232-239/047-000 232-240 232-240/005-000 232-240/005-000/039-000 232-240/031-000 232-240/039-000 232-240/047-000 232-241 232-241/005-000 232-241/005-000/039-000 232-241/031-000 232-241/039-000 232-241/047-000 232-242 232-242/005-000 232-242/005-000/039-000 232-242/031-000 232-242/039-000 232-242/047-000 232-243 232-243/005-000 232-243/005-000/039-000 232-243/031-000 232-243/039-000 232-243/047-000 232-244 232-244/005-000 232-244/005-000/039-000 232-244/031-000 232-244/039-000 232-244/047-000 232-245 232-245/005-000 232-245/005-000/039-000 232-245/031-000 232-245/039-000 232-245/047-000 232-246 232-246/005-000 232-246/005-000/039-000 232-246/031-000 232-246/039-000 232-246/047-000 232-247 232-247/005-000 232-247/005-000/039-000 232-247/031-000 232-247/039-000 232-247/047-000 232-248 232-248/005-000 232-248/005-000/039-000 232-248/031-000 232-248/039-000 232-248/047-000 232-249 232-249/005-000 232-249/005-000/039-000 232-249/031-000 232-249/039-000
232241/031000, 232 241/031 000
