Datasheet Wago 232-262/031-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; зажимное кольцо; Шаг контактов 5,08 мм; 2-пол.
THT FEMALE HEADER; 0.6 X 1.0 MM | |||
| 232-262/031-000 Wago | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 18.25 mm / 0.719 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.05 MJ |
| GTIN | 4044918625173 |
| Height | 16.6 mm / 0.654 inch |
| Height from the surface | 11.6 mm / 0.457 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 2 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 2 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 2.65 г |
| Ширина | 24.96 mm / 0.983 inch |
Серия: 232 (100 из 896)
- 232-245/031-000 232-245/039-000 232-245/047-000 232-246 232-246/005-000 232-246/005-000/039-000 232-246/031-000 232-246/039-000 232-246/047-000 232-247 232-247/005-000 232-247/005-000/039-000 232-247/031-000 232-247/039-000 232-247/047-000 232-248 232-248/005-000 232-248/005-000/039-000 232-248/031-000 232-248/039-000 232-248/047-000 232-249 232-249/005-000 232-249/005-000/039-000 232-249/031-000 232-249/039-000 232-249/047-000 232-250 232-250/005-000 232-250/005-000/039-000 232-250/031-000 232-250/039-000 232-250/047-000 232-251 232-251/031-000 232-251/039-000 232-251/047-000 232-252 232-252/031-000 232-252/039-000 232-252/047-000 232-253 232-253/031-000 232-253/039-000 232-253/047-000 232-254 232-254/031-000 232-254/039-000 232-254/047-000 232-262 232-262/031-000 232-262/039-000 232-262/047-000 232-263 232-263/031-000 232-263/039-000 232-263/047-000 232-264 232-264/031-000 232-264/039-000 232-264/047-000 232-265 232-265/031-000 232-265/039-000 232-265/047-000 232-266 232-266/031-000 232-266/039-000 232-266/047-000 232-267 232-267/031-000 232-267/039-000 232-267/047-000 232-268 232-268/031-000 232-268/039-000 232-268/047-000 232-269 232-269/031-000 232-269/039-000 232-269/047-000 232-270 232-270/031-000 232-270/039-000 232-270/047-000 232-271 232-271/031-000 232-271/039-000 232-271/047-000 232-272 232-272/031-000 232-272/039-000 232-272/047-000 232-273 232-273/031-000 232-273/039-000 232-273/047-000 232-274 232-274/031-000 232-274/039-000
232262/031000, 232 262/031 000
