Datasheet Wago 232-266/047-000 — Даташит
Серия232
Модель232-266/047-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Проходной фланец; Шаг контактов 5,08 мм; 6-пол.
Цветorange
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина18.25 mm / 0.719 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.115 MJ
GTIN4044918625432
Height16.6 mm / 0.654 inch
Height from the surface11.6 mm / 0.457 inch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles6
Number of levels1
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current12 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of connection points6
Total number of potentials6
Type of mountingFlush mounting Panel mounting
Вес6.178 г
Ширина45.28 mm / 1.783 inch
232266/047000, 232 266/047 000
На английском языке: Datasheet Wago 232-266/047-000
