Datasheet Wago 232-268/047-000 — Даташит
Серия232
Модель232-268/047-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Проходной фланец; Шаг контактов 5,08 мм; 8-пол.
Axial Lead and Cartridge Fuses - Designed to METI Standard
МосЧип
Littelfuse
Цветorange
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина18.25 mm / 0.719 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.143 MJ
GTIN4050821627838
Height16.6 mm / 0.654 inch
Height from the surface11.6 mm / 0.457 inch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles8
Number of levels1
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current12 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of potentials8
Type of mountingFlush mounting Panel mounting
Вес7.898 г
Ширина55.44 mm / 2.183 inch
232268/047000, 232 268/047 000
На английском языке: Datasheet Wago 232-268/047-000
