Datasheet Wago 232-271/031-000 — Даташит
Серия232
Модель232-271/031-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; зажимное кольцо; Шаг контактов 5,08 мм; 11-пол.
2.54mm (.100) Pitch KK?® Solid Header, Vertical, with Friction Lock, 27 Circuits, Tin (Sn) Plating
МосЧип
2.32271e+011
Molex
232-271-JT
Littelfuse
232-271-JB
Littelfuse
Цветorange
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина18.25 mm / 0.719 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
GTIN4055143576895
Height16.6 mm / 0.654 inch
Height from the surface11.6 mm / 0.457 inch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles11
Number of levels1
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current12 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of potentials11
Type of mountingFeed-through mounting Panel mounting
Вес10.194 г
Ширина70.68 mm / 2.783 inch
232271/031000, 232 271/031 000
На английском языке: Datasheet Wago 232-271/031-000
