Datasheet Wago 232-273 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Шаг контактов 5,08 мм; 13-пол.
| 2.32273e+009 | по запросу | ||
| 2,32273E+11 | по запросу | ||
| 2.32273e+016 | по запросу | ||
| 2.32273e+011 | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 18.25 mm / 0.719 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.187 MJ |
| GTIN | 4044918579582 |
| Height | 16.6 mm / 0.654 inch |
| Height from the surface | 11.6 mm / 0.457 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 13 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of connection points | 13 |
| Total number of potentials | 13 |
| Вес | 12 г |
| Ширина | 67.54 mm / 2.659 inch |
Серия: 232 (100 из 896)
- 232-253/039-000 232-253/047-000 232-254 232-254/031-000 232-254/039-000 232-254/047-000 232-262 232-262/031-000 232-262/039-000 232-262/047-000 232-263 232-263/031-000 232-263/039-000 232-263/047-000 232-264 232-264/031-000 232-264/039-000 232-264/047-000 232-265 232-265/031-000 232-265/039-000 232-265/047-000 232-266 232-266/031-000 232-266/039-000 232-266/047-000 232-267 232-267/031-000 232-267/039-000 232-267/047-000 232-268 232-268/031-000 232-268/039-000 232-268/047-000 232-269 232-269/031-000 232-269/039-000 232-269/047-000 232-270 232-270/031-000 232-270/039-000 232-270/047-000 232-271 232-271/031-000 232-271/039-000 232-271/047-000 232-272 232-272/031-000 232-272/039-000 232-272/047-000 232-273 232-273/031-000 232-273/039-000 232-273/047-000 232-274 232-274/031-000 232-274/039-000 232-274/047-000 232-275 232-275/031-000 232-275/039-000 232-275/047-000 232-276 232-276/031-000 232-276/039-000 232-276/047-000 232-277 232-277/031-000 232-277/039-000 232-277/047-000 232-278 232-278/031-000 232-278/039-000 232-278/047-000 232-279 232-279/031-000 232-279/039-000 232-279/047-000 232-280 232-280/031-000 232-280/039-000 232-280/047-000 232-281 232-281/031-000 232-281/039-000 232-281/047-000 232-282 232-282/031-000 232-282/039-000 232-282/047-000 232-283 232-283/031-000 232-283/039-000 232-283/047-000 232-284 232-284/031-000 232-284/039-000 232-284/047-000 232-302/026-000 232-303/026-000
