Datasheet Wago 232-284/039-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Фиксирующий рычаг; Шаг контактов 5,08 мм; 24-пол.
| THT FEMALE HEADER; 0.6 X 1.0 MM | |||
| 232-284 Wago | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 18.25 mm / 0.719 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.365 MJ |
| GTIN | 4044918625715 |
| Height | 16.6 mm / 0.654 inch |
| Height from the surface | 11.6 mm / 0.457 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 24 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of connection points | 24 |
| Total number of potentials | 24 |
| Вес | 21.6 г |
| Ширина | 137.72 mm / 5.422 inch |
Серия: 232 (100 из 896)
- 232-272 232-272/031-000 232-272/039-000 232-272/047-000 232-273 232-273/031-000 232-273/039-000 232-273/047-000 232-274 232-274/031-000 232-274/039-000 232-274/047-000 232-275 232-275/031-000 232-275/039-000 232-275/047-000 232-276 232-276/031-000 232-276/039-000 232-276/047-000 232-277 232-277/031-000 232-277/039-000 232-277/047-000 232-278 232-278/031-000 232-278/039-000 232-278/047-000 232-279 232-279/031-000 232-279/039-000 232-279/047-000 232-280 232-280/031-000 232-280/039-000 232-280/047-000 232-281 232-281/031-000 232-281/039-000 232-281/047-000 232-282 232-282/031-000 232-282/039-000 232-282/047-000 232-283 232-283/031-000 232-283/039-000 232-283/047-000 232-284 232-284/031-000 232-284/039-000 232-284/047-000 232-302/026-000 232-303/026-000 232-304/026-000 232-305/026-000 232-306/026-000 232-307/026-000 232-308/026-000 232-309/026-000 232-310/026-000 232-311/026-000 232-312/026-000 232-313/026-000 232-314/026-000 232-315/026-000 232-316/026-000 232-317/026-000 232-318/026-000 232-319/026-000 232-320/026-000 232-321/026-000 232-322/026-000 232-323/026-000 232-324/026-000 232-332 232-333 232-334 232-335 232-336 232-337 232-338 232-340 232-342 232-346 232-362 232-363 232-364 232-366 232-368 232-370 232-372 232-376 232-402/026-000 232-403/026-000 232-404/026-000 232-405/026-000 232-406/026-000 232-407/026-000 232-408/026-000
232284/039000, 232 284/039 000
