Datasheet Wago 232-307/026-000 — Даташит
Серия232
Модель232-307/026-000
1-проводниковая розетка; угловые; 2,5 мм²; Шаг контактов 5,08 мм; 7-пол.
Axial Lead and Cartridge Fuses - Designed to METI Standard
Littelfuse
Actuation typeOperating tool
Цветorange
Conductor entry direction to mating direction270 °
Contact materialCopper alloy
Contact platingtin-plated
Country of originPL
Габариты: глубина22.75 mm / 0.896 inch
Designangled
Fire load0.213 MJ
GTIN4044918385527
Height23.9 mm / 0.941 inch
Material groupI
Mismating protectionNo
Number of Poles7
Number of connection types1
Number of levels1
Pin spacing5.08 mm (0.2 inch)
Rated current14 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Total number of connection points7
Total number of potentials7
Вес13.111 г
Ширина37.96 mm / 1.494 inch
232307/026000, 232 307/026 000
На английском языке: Datasheet Wago 232-307/026-000
