Datasheet Wago 232-409/026-000 — Даташит
1-проводниковая розетка; угловые; 2,5 мм²; Шаг контактов 5,08 мм; 9-пол.
Купить 232-409/026-000 на РадиоЛоцман.Цены — от 1 468 до 1 940 ₽14 предложений от 4 поставщиков 1-CONDUCTOR FEMALE PLUG; ANGLED; | |||
| 232-409/026-000 | от 1 468 ₽ | ||
| 232-409/026-000 Wago | от 1 676 ₽ | ||
| 232-409/026-000 Wago | 1 940 ₽ | ||
| 232-409/026-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Conductor entry direction to mating direction | 90 ° |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 22.75 mm / 0.896 inch |
| Design | angled |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.277 MJ |
| GTIN | 4044918389891 |
| Height | 19.9 mm / 0.783 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 9 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 14 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 9 |
| Total number of potentials | 9 |
| Вес | 16.935 г |
| Ширина | 48.12 mm / 1.894 inch |
Серия: 232 (100 из 896)
- 232-284/039-000 232-284/047-000 232-302/026-000 232-303/026-000 232-304/026-000 232-305/026-000 232-306/026-000 232-307/026-000 232-308/026-000 232-309/026-000 232-310/026-000 232-311/026-000 232-312/026-000 232-313/026-000 232-314/026-000 232-315/026-000 232-316/026-000 232-317/026-000 232-318/026-000 232-319/026-000 232-320/026-000 232-321/026-000 232-322/026-000 232-323/026-000 232-324/026-000 232-332 232-333 232-334 232-335 232-336 232-337 232-338 232-340 232-342 232-346 232-362 232-363 232-364 232-366 232-368 232-370 232-372 232-376 232-402/026-000 232-403/026-000 232-404/026-000 232-405/026-000 232-406/026-000 232-407/026-000 232-408/026-000 232-409/026-000 232-410/026-000 232-411/026-000 232-411/026-000/035-000 232-412/026-000 232-413/026-000 232-414/026-000 232-415/026-000 232-416/026-000 232-417/026-000 232-418/026-000 232-419/026-000 232-420/026-000 232-421/026-000 232-422/026-000 232-423/026-000 232-424/026-000 232-502/007-000 232-503/007-000 232-504/007-000 232-505/007-000 232-506/007-000 232-507/007-000 232-508/007-000 232-509/007-000 232-510/007-000 232-511/007-000 232-512/007-000 232-513/007-000 232-514/007-000 232-515/007-000 232-516/007-000 232-517/007-000 232-518/007-000 232-519/007-000 232-520/007-000 232-521/007-000 232-522/007-000 232-523/007-000 232-524/007-000 232-532/007-000 232-533/007-000 232-534/007-000 232-535/007-000 232-536/007-000 232-537/007-000 232-538/007-000 232-539/007-000 232-540/007-000 232-541/007-000
232409/026000, 232 409/026 000
