Datasheet Wago 232-420/026-000 — Даташит
Серия232
Модель232-420/026-000
1-проводниковая розетка; угловые; 2,5 мм²; Шаг контактов 5,08 мм; 20-пол.
Axial Lead and Cartridge Fuses - Designed to METI Standard
LifeElectronics
Littelfuse
Actuation typeOperating tool
Цветorange
Conductor entry direction to mating direction90 °
Contact materialCopper alloy
Contact platingtin-plated
Country of originPL
Габариты: глубина22.75 mm / 0.896 inch
Designangled
Fire load0.607 MJ
GTIN4044918390255
Height19.9 mm / 0.783 inch
Material groupI
Mismating protectionNo
Number of Poles20
Number of connection types1
Number of levels1
Pin spacing5.08 mm (0.2 inch)
Rated current14 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Total number of connection points20
Total number of potentials20
Вес37.34 г
Ширина104 mm / 4.094 inch
232420/026000, 232 420/026 000
На английском языке: Datasheet Wago 232-420/026-000
