Datasheet Wago 232-506/007-000 — Даташит
Штекерная часть электрического соединителя с двумя выводами; DIN-35 rail mounting; Шаг контактов 5 мм; 6-пол.
DOUBLE PIN HEADER; DIN-35 RAIL M | |||
| 232-506/007-000 Wago | по запросу | ||
| Цвет | gray |
| Connector connection type | for pluggable connectors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 42.5 mm / 1.673 inch |
| Fire load | 0.162 MJ |
| GTIN | 4045454339364 |
| Height from upper-edge of DIN-35 rail | 15 mm / 0.591 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 6 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Ratings note | Notice: Male connectors shall not be live when disconnected! |
| Total number of potentials | 6 |
| Type of mounting | DIN-35 rail |
| Вес | 7.196 г |
| Ширина | 33.2 mm / 1.307 inch |
Серия: 232 (100 из 896)
- 232-321/026-000 232-322/026-000 232-323/026-000 232-324/026-000 232-332 232-333 232-334 232-335 232-336 232-337 232-338 232-340 232-342 232-346 232-362 232-363 232-364 232-366 232-368 232-370 232-372 232-376 232-402/026-000 232-403/026-000 232-404/026-000 232-405/026-000 232-406/026-000 232-407/026-000 232-408/026-000 232-409/026-000 232-410/026-000 232-411/026-000 232-411/026-000/035-000 232-412/026-000 232-413/026-000 232-414/026-000 232-415/026-000 232-416/026-000 232-417/026-000 232-418/026-000 232-419/026-000 232-420/026-000 232-421/026-000 232-422/026-000 232-423/026-000 232-424/026-000 232-502/007-000 232-503/007-000 232-504/007-000 232-505/007-000 232-506/007-000 232-507/007-000 232-508/007-000 232-509/007-000 232-510/007-000 232-511/007-000 232-512/007-000 232-513/007-000 232-514/007-000 232-515/007-000 232-516/007-000 232-517/007-000 232-518/007-000 232-519/007-000 232-520/007-000 232-521/007-000 232-522/007-000 232-523/007-000 232-524/007-000 232-532/007-000 232-533/007-000 232-534/007-000 232-535/007-000 232-536/007-000 232-537/007-000 232-538/007-000 232-539/007-000 232-540/007-000 232-541/007-000 232-542/007-000 232-543/007-000 232-544/007-000 232-545/007-000 232-546/007-000 232-547/007-000 232-548/007-000 232-549/007-000 232-550/007-000 232-551/007-000 232-552/007-000 232-553/007-000 232-554/007-000 232-562/007-000 232-563/007-000 232-564/007-000 232-565/007-000 232-566/007-000 232-567/007-000 232-568/007-000 232-569/007-000
232506/007000, 232 506/007 000
