Datasheet Wago 232-732 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; Шаг контактов 7,5 мм; 2-пол.
![]() 18 предложений от 6 поставщиков THT FEMALE HEADER; 0.6 X 1.0 MM | |||
232-732 | от 290 ₽ | ||
232-732 Wago | от 322 ₽ | ||
232-732 Wago | от 354 ₽ | ||
232-732/045-000 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 11.6 mm / 0.457 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fire load | 0.041 MJ |
GTIN | 4044918579704 |
Height | 23.25 mm / 0.915 inch |
Height from the surface | 18.25 mm / 0.719 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 2 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 2 |
Вес | 2.15 г |
Ширина | 14 mm / 0.551 inch |
Серия: 232 (100 из 896)
- 232-566/007-000 232-567/007-000 232-568/007-000 232-569/007-000 232-570/007-000 232-571/007-000 232-572/007-000 232-582/007-000 232-583/007-000 232-584/007-000 232-585/007-000 232-586/007-000 232-587/007-000 232-588/007-000 232-589/007-000 232-590/007-000 232-591/007-000 232-592/007-000 232-602 232-603 232-604 232-605 232-606 232-607 232-608 232-609 232-610 232-612 232-632 232-633 232-634 232-635 232-636 232-637 232-638 232-639 232-640 232-642 232-646 232-662 232-663 232-664 232-665 232-667 232-670 232-682 232-683 232-684 232-685 232-687 232-732 232-732/031-000 232-732/039-000 232-732/045-000 232-732/047-000 232-733 232-733/031-000 232-733/039-000 232-733/045-000 232-733/047-000 232-734 232-734/031-000 232-734/039-000 232-734/045-000 232-734/047-000 232-735 232-735/031-000 232-735/039-000 232-735/045-000 232-735/047-000 232-736 232-736/031-000 232-736/039-000 232-736/045-000 232-736/047-000 232-737 232-737/031-000 232-737/039-000 232-737/045-000 232-737/047-000 232-738 232-738/031-000 232-738/039-000 232-738/045-000 232-738/047-000 232-739 232-739/031-000 232-739/039-000 232-739/045-000 232-739/047-000 232-740 232-740/031-000 232-740/039-000 232-740/045-000 232-740/047-000 232-741 232-741/031-000 232-741/039-000 232-741/045-000 232-741/047-000
