Datasheet Wago 232-745/045-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; Шаг контактов 7,5 мм; 15-пол.
| Цвет | gray |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 11.6 mm / 0.457 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.313 MJ |
| GTIN | 4055143034043 |
| Height | 22.05 mm / 0.868 inch |
| Height from the surface | 18.25 mm / 0.719 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 15 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Packaging type | BOX |
| Pin spacing | 7.5 mm (0.295 inch) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 3.8 мм |
| Total number of potentials | 15 |
| Вес | 16.55 г |
| Ширина | 111.5 mm / 4.39 inch |
Серия: 232 (100 из 896)
- 232-734/031-000 232-734/039-000 232-734/045-000 232-734/047-000 232-735 232-735/031-000 232-735/039-000 232-735/045-000 232-735/047-000 232-736 232-736/031-000 232-736/039-000 232-736/045-000 232-736/047-000 232-737 232-737/031-000 232-737/039-000 232-737/045-000 232-737/047-000 232-738 232-738/031-000 232-738/039-000 232-738/045-000 232-738/047-000 232-739 232-739/031-000 232-739/039-000 232-739/045-000 232-739/047-000 232-740 232-740/031-000 232-740/039-000 232-740/045-000 232-740/047-000 232-741 232-741/031-000 232-741/039-000 232-741/045-000 232-741/047-000 232-742 232-742/031-000 232-742/039-000 232-742/045-000 232-742/047-000 232-743 232-743/031-000 232-743/039-000 232-743/045-000 232-743/047-000 232-744/045-000 232-745/045-000 232-746 232-746/031-000 232-746/039-000 232-746/045-000 232-746/047-000 232-762 232-762/031-000 232-762/039-000 232-762/045-000 232-762/047-000 232-763 232-763/031-000 232-763/039-000 232-763/045-000 232-763/047-000 232-764 232-764/031-000 232-764/039-000 232-764/045-000 232-764/047-000 232-765 232-765/031-000 232-765/039-000 232-765/045-000 232-765/047-000 232-766 232-766/031-000 232-766/039-000 232-766/045-000 232-766/047-000 232-767 232-767/031-000 232-767/039-000 232-767/045-000 232-767/047-000 232-768 232-768/031-000 232-768/039-000 232-768/045-000 232-768/047-000 232-769 232-769/031-000 232-769/039-000 232-769/045-000 232-769/047-000 232-770 232-770/031-000 232-770/039-000 232-770/045-000
232745/045000, 232 745/045 000
