Datasheet Wago 232-834 — Даташит
Серия232
Модель232-834
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Шаг контактов 7,5 мм; 4-пол.
Axial Lead and Cartridge Fuses - Designed to METI Standard
TradeElectronics
Littelfuse
Wago 232-834
Цветgray
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина18.25 mm / 0.719 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.082 MJ
GTIN4044918580069
Height16.6 mm / 0.654 inch
Height from the surface11.6 mm / 0.457 inch
Material groupI
Mismating protectionNo
Number of Poles4
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current12 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of potentials4
Вес4.34 г
Ширина29 mm / 1.142 inch
На английском языке: Datasheet Wago 232-834
