Datasheet Wago 232-841/045-000 — Даташит
Серия232
Модель232-841/045-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Шаг контактов 7,5 мм; 11-пол.
Цветgray
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина18.25 mm / 0.719 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.229 MJ
GTIN4055143034210
Height15.4 mm / 0.606 inch
Height from the surface11.6 mm / 0.457 inch
Material groupI
Mismating protectionNo
Number of Poles11
Number of levels1
PCB contactTHT
Packaging typeBOX
Pin spacing7.5 mm (0.295 inch)
Rated current12 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length3.8 мм
Total number of potentials11
Вес12.11 г
Ширина81.5 mm / 3.209 inch
232841/045000, 232 841/045 000
На английском языке: Datasheet Wago 232-841/045-000
