Datasheet Wago 232-864/047-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Проходной фланец; Шаг контактов 7,62 мм; 4-пол.
| THT FEMALE HEADER; 0.6 X 1.0 MM | |||
| 232-864/031-000 Wago | по запросу | ||
| 232-864 Wago | по запросу | ||
| NCA232864 CIT Relay & Switch | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 18.25 mm / 0.719 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.109 MJ |
| GTIN | 4017332538459 |
| Height | 16.6 mm / 0.654 inch |
| Height from the surface | 11.6 mm / 0.457 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 4 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 7.62 mm (0.3 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 4 |
| Type of mounting | Flush mounting Panel mounting |
| Вес | 5.198 г |
| Ширина | 42.74 mm / 1.683 inch |
Серия: 232 (100 из 896)
- 232-836/039-000 232-836/045-000 232-836/047-000 232-837 232-837/031-000 232-837/039-000 232-837/045-000 232-837/047-000 232-838 232-838/031-000 232-838/039-000 232-838/045-000 232-838/047-000 232-839 232-839/031-000 232-839/039-000 232-839/045-000 232-839/047-000 232-840 232-840/031-000 232-840/039-000 232-840/045-000 232-840/047-000 232-841 232-841/031-000 232-841/039-000 232-841/045-000 232-841/047-000 232-842 232-842/031-000 232-842/039-000 232-842/045-000 232-842/047-000 232-843 232-843/031-000 232-843/039-000 232-843/045-000 232-843/047-000 232-844/045-000 232-845/045-000 232-846 232-846/031-000 232-846/039-000 232-846/045-000 232-846/047-000 232-862 232-862/031-000 232-862/039-000 232-862/045-000 232-862/047-000 232-863 232-863/031-000 232-863/039-000 232-863/045-000 232-863/047-000 232-864 232-864/031-000 232-864/039-000 232-864/045-000 232-864/047-000 232-865 232-865/031-000 232-865/039-000 232-865/045-000 232-865/047-000 232-866 232-866/031-000 232-866/039-000 232-866/045-000 232-866/047-000 232-867 232-867/031-000 232-867/039-000 232-867/045-000 232-867/047-000 232-868 232-868/031-000 232-868/039-000 232-868/045-000 232-868/047-000 232-869 232-869/031-000 232-869/039-000 232-869/045-000 232-869/047-000 232-870 232-870/031-000 232-870/039-000 232-870/045-000 232-870/047-000 232-871 232-871/031-000 232-871/039-000 232-871/045-000 232-871/047-000 232-872 232-872/031-000 232-872/039-000 232-872/045-000 232-872/047-000
232864/047000, 232 864/047 000
