Datasheet Wago 232-867/045-000 — Даташит
Серия232
Модель232-867/045-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Шаг контактов 7,62 мм; 7-пол.
+5 V Powered CMOS RS-232 Drivers/Receivers
LifeElectronics
AD2328-67
Цветorange
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина18.25 mm / 0.719 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.149 MJ
GTIN4055143034333
Height15.4 mm / 0.606 inch
Height from the surface11.6 mm / 0.457 inch
Material groupI
Mismating protectionNo
Number of Poles7
Number of levels1
PCB contactTHT
Packaging typeBOX
Pin spacing7.62 mm (0.3 inch)
Rated current12 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length3.8 мм
Total number of potentials7
Вес7.67 г
Ширина57.98 mm / 2.059 inch
232867/045000, 232 867/045 000
На английском языке: Datasheet Wago 232-867/045-000
