Оптопары и оптореле Megawin
Datasheet Wago 232-868/031-000 — Даташит
Серия232
Модель232-868/031-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; зажимное кольцо; Шаг контактов 7,62 мм; 8-пол.
Axial Lead and Cartridge Fuses - Designed to METI Standard
TradeElectronics
AD2328-68
МосЧип
Littelfuse
Цветorange
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина18.25 mm / 0.719 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.188 MJ
GTIN4017332538589
Height16.6 mm / 0.654 inch
Height from the surface11.6 mm / 0.457 inch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles8
Number of levels1
PCB contactTHT
Pin spacing7.62 mm (0.3 inch)
Rated current12 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of potentials8
Type of mountingFeed-through mounting Panel mounting
Вес9.36 г
Ширина73.22 mm / 2.883 inch
232868/031000, 232 868/031 000
На английском языке: Datasheet Wago 232-868/031-000
