Datasheet Wago 233-148 — Даташит
Серия233
Модель233-148
Клеммная колодка для печатной платы; 0,5 мм²; Шаг контактов 2,5 мм; 48-полюсный; CAGE CLAMP
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB30 °
Contact platingtin-plated
Country of originCH
Габариты: глубина12.1 mm / 0.476 inch
Fine-stranded conductor0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 mm²
Fire load0.196 MJ
GTIN4045454050818
Height15.7 mm / 0.618 inch
Height from the surface11.7 mm / 0.461 inch
Material groupI
Number of Poles48
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing2.5 mm (0.098 inch)
Rated current6 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)160 В
Rated voltage (III / 3)63 В
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.08 … 0.5 mm² / 28 … 20 AWG
Total number of connection points48
Total number of potentials48
Вес16.11 г
Ширина122.3 mm / 4.815 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 233-148
