Datasheet Wago 233-202 — Даташит
клеммная колодка для печатной платы; Нажать кнопку; 0,5 мм²; Расстояние между контактами 2,5 мм; 2-полюсный; ЗАЖИМ ДЛЯ КЛЕТКИ
|  Купить 233-202 на РадиоЛоцман.Цены — от 86 до 277 ₽ 23 предложений от 9 поставщиков Клеммная колодка типа провод к плате, 2.5 мм, 2 вывод(-ов), 28 AWG, 20 AWG, 0.5 мм², Вставной | |||
| 233-202 Wago | 86 ₽ | ||
| 233-202 | от 187 ₽ | ||
| 233-202 | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 30 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 13.9 mm / 0.547 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 mm² |
| Fire load | 0.016 MJ |
| GTIN | 4045454049423 |
| Height | 19.5 mm / 0.768 inch |
| Height from the surface | 15.5 mm / 0.61 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 2.5 mm (0.098 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 6 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 63 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Вес | 0.908 г |
| Ширина | 7.3 mm / 0.287 inch |
Серия: 233 (56)
- 233-102 233-103 233-104 233-105 233-106 233-107 233-108 233-109 233-110 233-112 233-116 233-124 233-136 233-148 233-202 233-203 233-204 233-205 233-206 233-207 233-208 233-209 233-210 233-212 233-216 233-224 233-236 233-248 233-402 233-403 233-404 233-405 233-406 233-407 233-408 233-409 233-410 233-412 233-416 233-424 233-436 233-448 233-502 233-503 233-504 233-505 233-506 233-507 233-508 233-509 233-510 233-512 233-516 233-524 233-536 233-548
- PCB Interconnect
