Datasheet Wago 233-207 — Даташит
Клеммная колодка для печатной платы; Кнопка; 0,5 мм²; Шаг контактов 2,5 мм; 7-полюсный; CAGE CLAMP
![]() 11 предложений от 10 поставщиков 233-207, 7-проводная клеммная колодка, шаг 2,5 мм, на плату, серая | |||
233-207-00ZL15-19SN | от 237 638 ₽ | ||
233-207 | по запросу | ||
233-207-00ZL15-19SN Glenair | по запросу | ||
233-207 Wago | по запросу |
Actuation type | Push-button |
Цвет | gray |
Conductor entry angle to the PCB | 30 ° |
Country of origin | CH |
Габариты: глубина | 13.9 mm / 0.547 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 mm² |
Fire load | 0.046 MJ |
GTIN | 4045454049485 |
Height | 19.5 mm / 0.768 inch |
Height from the surface | 15.5 mm / 0.61 inch |
Material group | I |
Number of Poles | 7 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 2.5 mm (0.098 inch) |
Rated current | 6 A |
Rated voltage (III / 3) | 63 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
Total number of connection points | 7 |
Total number of potentials | 7 |
Вес | 2.863 г |
Ширина | 19.8 mm / 0.78 inch |
Серия: 233 (56)
- 233-102 233-103 233-104 233-105 233-106 233-107 233-108 233-109 233-110 233-112 233-116 233-124 233-136 233-148 233-202 233-203 233-204 233-205 233-206 233-207 233-208 233-209 233-210 233-212 233-216 233-224 233-236 233-248 233-402 233-403 233-404 233-405 233-406 233-407 233-408 233-409 233-410 233-412 233-416 233-424 233-436 233-448 233-502 233-503 233-504 233-505 233-506 233-507 233-508 233-509 233-510 233-512 233-516 233-524 233-536 233-548
- PCB Interconnect
