Datasheet Wago 233-448 — Даташит
Серия233
Модель233-448
Клеммная колодка для печатной платы; 0,5 мм²; Шаг контактов 2,54 мм; 48-полюсный; CAGE CLAMP
Элитан
Y233448 (ALTERNATE: Y233448)
Mersen
1 593 ₽
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB30 °
Contact platingtin-plated
Country of originCH
Габариты: глубина12.1 mm / 0.476 inch
Fine-stranded conductor0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 mm²
Fire load0.244 MJ
GTIN4045454051242
Height15.7 mm / 0.618 inch
Height from the surface11.7 mm / 0.461 inch
Material groupI
Number of Poles48
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing2.54 mm (0.1 inch)
Rated current6 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)160 В
Rated voltage (III / 3)63 В
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.08 … 0.5 mm² / 28 … 20 AWG
Total number of connection points48
Total number of potentials48
Вес16.394 г
Ширина124.22 mm / 4.891 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 233-448
